Old 06-14-2005, 09:09 PM   #1
crazy9ceguy
crazy9ceguy is on a distinguished road
Send a message via AIM to crazy9ceguy
bleeding power steering on sr20
hi i have a s13 redtop, i was just wndering how do you bleed the power steering system? and what fluid do i use? my car's steering gets pretty stiff after i drive it around. but in the morning its fine.
crazy9ceguy is offline   Reply With Quote
Old 06-14-2005, 09:35 PM   #2
Dousan_PG
Dousan_PG's Avatar
Dousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfection
easiest way
jack up front of car to get both wheels off ground
remove cap for power steering reservior
turn steering wheel to full lock ot one side
turn steering wheel to full lock other side
repeat until all bubbles ar out of the PS reservoir.
done and done
takes 10 mins if that. so easy.
Aaron
Pink GodziRa
www.geocities.com/pink_godzira
Dousan_PG is offline   Reply With Quote
Old 06-14-2005, 09:48 PM   #3
Phlip
Phlip's Avatar
^^^ That is a tried and true method, that is how my KA was bled, it would make perfect sense for your SR... Oh and, to answer the thread starter's OTHER question: PS fluid = autozone Automatic Transmission Fluid, 1-3 bux
And I write too!
Old 06-14-2005, 10:03 PM   #4
crazy9ceguy
oh yea i fergot how do you flush it? the fluid is really dark and thick. so its time to change it.
Old 06-14-2005, 10:10 PM   #5
Dousan_PG
Dousan_PG's Avatar
pull the hose off. lowest one of course. that is what i would think.
Aaron
Pink GodziRa
Old 06-14-2005, 10:21 PM   #6
Phlip
Phlip's Avatar
I agree with Dousan this time, there is no specific reference to it in the FSM, I was looking at it while he answered... I say disconnect the lower most hose, point it into a bucket, start car, turn wheel til fuid stops coming out of it, cut the car off start filling the reservoir, start the car back up, then follow the steps he gave for bleeding, as that IS what the FSM specifies.
And I write too!
Old 06-14-2005, 11:01 PM   #7
crazy9ceguy
thanks alot, i will try it on thursday when i get my car out of the body shop.
Old 06-15-2005, 11:37 AM   #8
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
I've never had a problem with just lifting the front and turning the wheel back and forth for awhile.
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
Old 06-15-2005, 01:27 PM   #9
SDS14Driver
SDS14Driver is an unknown quantity at this point
"oh yea i fergot how do you flush it? the fluid is really dark and thick. so its time to change it."
Turkey baster. ;p
SDS14Driver is offline   Reply With Quote
Old 06-15-2005, 02:10 PM   #10
Var
Var's Avatar
Var is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of light
Send a message via AIM to Var
pull the hard lines off the rack, turn the wheel from lock to lock to let all the fluid out of the rack. Take the hose off and run the motor. haha
Hi
Var is offline   Reply With Quote
Old 06-15-2005, 02:23 PM   #11
SDS14Driver
TURKEY BASTER! ;p
jk, do what the pimp says. What do i know...
