Old 08-20-2008, 07:53 PM   #1
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
is this the right fitting?
im upgrading to an s15 turbo, for my red-top, i already have cs braided lines and i want to get rid of the stock banjo bolt for the oil feed line and this is the only fitting that i found, is this the correct one?
Pegasus -Male 12 x 1.25mm Metric Convex Seat to 3AN Male, Steel
also will i need a .06 or .03 restrictor?
japslapsilvia is offline   Reply With Quote
Old 08-20-2008, 11:58 PM   #2
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
this may help
I wouldn't usually reply if I didn't know the answer but it doesn't look like your getting much help
http://zilvia.net/f/tech-talk/186122...ch-thread.html
JRas is offline   Reply With Quote
Old 08-21-2008, 06:48 AM   #3
japslapsilvia
Originally Posted by JRas View Post
this may help
cool thanks so that is the right fitting.
does anyone know what size restrictor i will need the .03 or .06
