Old 09-27-2012, 04:18 PM   #1
ESone3
ESone3's Avatar
ESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of light
iLL Garage: R34 GTT to R34 GTR conversion
To start, we must give a little background on this car. This R34 started its life as a GTT rear wheel drive platform and was then recruited to become a stunt double for the hero car for the Fast and Furious 4 movie. This car was one of the lucky few that didn’t crashed and was able to be saved by the current owner. We received a phone call from the customer wanting and RB26 full AWD swap into a R34 GTS RWD. We thought to ourselves, no big deal, same chassis right?? WRONG! After scoping the project details, we found out the chassis are completely different. The best way to explain this is trying to make a 240sx AWD, not a bolt on affair. Several modifications needed to be made for this swap to work, customized trans tunnel, custom trans mount, custom driveshaft, full front and rear subframe modifications, and the list continues.
The star of the movie… not guy, the car!
Before it went under the knife.
The transplant, NISMO R RB26DETT packed full of every NISMO factory option.
Getting motor ready for final drop in. Its been in out a bunch of times.
Engine and trans in!
GTR Crossmember installed (GTT different), new mount points had to be made.
Tunnel had to be modified to fit the transfer case.
Their are more plans for the car, but so far its stupid fast.
Thanks for looking
www.illgarage.com
ESone3 is offline   Reply With Quote
Old 09-28-2012, 07:47 PM   #2
nissanduster
nissanduster is an unknown quantity at this point
Question where can I get a nismo rb engine.
nissanduster is offline   Reply With Quote
Old 09-29-2012, 02:19 AM   #3
MADE
MADE's Avatar
MADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant future
Yes the owner should have tried to source a GTX not a GTT. Even for shops to do it flawlessly with the AWD chassis it takes a bit of work. Good work.
MADE is offline   Reply With Quote
Old 09-30-2012, 04:48 AM   #4
C-unit
C-unit's Avatar
C-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to all
from Nismo
C-unit is offline   Reply With Quote
Old 09-30-2012, 02:13 PM   #5
drscooper
drscooper is an unknown quantity at this point
very nice man! hope to see more updates!
drscooper is offline   Reply With Quote
Old 09-30-2012, 09:53 PM   #6
NOOBdrifter
NOOBdrifter's Avatar
NOOBdrifter is an unknown quantity at this point
Wow, I really hope it's not the same Skyline as below in the article:
Fast & Furious Skyline stolen from Hollywood garage
NOOBdrifter is offline   Reply With Quote
Old 09-30-2012, 10:34 PM   #7
nissanduster
Hahaha that is funny but hope the car doesn't end up at a chop shop.
conversion, fast and furious, gtr, gtt, ill garage
