Old 03-22-2008, 09:38 PM   #1
SuicidnS13
SuicidnS13's Avatar
SuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruin
What size rivets to use for overfenders ect?
So guys when riveting on body parts what size rivets do you guys use? The short, medium or long ones? Also will it crack the fiberglass?
SuicidnS13 is offline   Reply With Quote
Old 03-23-2008, 01:36 PM   #2
akunochi
akunochi is an unknown quantity at this point
I would suggest a variety... You'll need to use the one that reaches through the body and overpanel
akunochi is offline   Reply With Quote
Old 03-23-2008, 01:47 PM   #3
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
You may want to use washers to help prevent cracking. I would use 3/16" diameter aluminum rivets. The steel ones would probably crack the fiberglass as they clamp quite a bit tighter. Just my opinion though as I have not installed any...........YET.
racepar1 is offline   Reply With Quote
Old 03-23-2008, 02:53 PM   #4
SuicidnS13
SuicidnS13's Avatar
Cool well I guess its all trial and error from here-
Old 09-24-2008, 12:36 PM   #5
Slow Poke
Slow Poke's Avatar
Slow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really nice
Anymore info on this?
thx
Slow Poke is offline   Reply With Quote
Old 09-24-2008, 02:29 PM   #6
Dousan_PG
Dousan_PG's Avatar
Dousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfection
i use 1/8" rivits
works fine
and gives u room if u need to replace any can go a size up if needs be
Aaron
Pink GodziRa
www.geocities.com/pink_godzira
Dousan_PG is offline   Reply With Quote
