Old 07-02-2010, 05:42 PM   #181
MitchellBade
MitchellBade's Avatar
MitchellBade is an unknown quantity at this point
This car is crazy! If I sell my life maybe I could do this. Now this is how you build a race car.
MitchellBade is offline   Reply With Quote
Old 07-02-2010, 06:00 PM   #182
FullRaceGeoff
FullRaceGeoff is an unknown quantity at this point
The new issue of modified magazine is on news stands, check it out!!
We got 2nd place in AWD class.
Full-Race has recently received a lot of PMs and emails now that the new issue of the Tuner shootout is on newstands. The updated R14 portion of the Full-Race.com site is coming next week, but to answer the basic questions, ill copy/paste the beginning text for you:
Full-Race.com -- R14 DIY HOW-TO info
this portion of the Full-Race.com website breaks down the R14 conversion in detail. Pictures and information help to make it clear how to do this AWD RB26 swap. If you've done a few different motor swaps, installed some turbokits, know how to use a hand-drill + welder (220 Volt Mig welder recommended), and are committed/prepared to take on a big project you can tackle this install. If you dont know how to do swaps or install aftermarket turbokits, do not start this conversion until you have more experience or better understand the process.
A) Required BIG parts:
-(95-98) S14 Chassis, S15 will work too. S13 will NOT work for this swap!! <
-R32 GTR front clip w/ complete front suspension and complete rear subframe <easy to find at any big JDM importers/yards>
-Full-Race R14 DIY kit
^^^If you can acquire all of the above items^^^ all the big purchases are out of the way.
B) Full-Race R14 kit consists of these parts required to do the swap:
R14 Frame Rails (Left and Right side)
R14 billet frame blocks
Subframe Bolts/washers
LHD RB26 steering rack
Transmission Mount
Frame side Transmission Mount-plate
Front Upper-Control-Arm Structure (Upper Shock mounts)
Lower Shock mounts
1-piece Driveshaft (Aluminum or Steel)
1/2" Eye-to-Eye Coilovers - Moton or Koni (Circletrack or Road Race style heim-mounted)
Here is how it all works, and enough instructions to get you going:
First, start by getting the R32 GTR clip fully disassembled. We will be using almost every major component from this clip. Keep all the suspension control arms, brakes, hubs and bolts sorted, with their respective hardware. The engine and transmission should be inspected and it is recommended to refresh it - new timing belt, clutch, oil pump, etc. At this point, the subframe should be unbolted from the motor mounts and then cleaned/prepped for the swap....
to be continued. Thanks for the interest in the R14 conversions!
FullRaceGeoff is offline   Reply With Quote
Old 07-03-2010, 12:02 AM   #183
90white240
90white240's Avatar
90white240 is an unknown quantity at this point
Bad a$$$$$
90white240 is offline   Reply With Quote
Old 07-03-2010, 01:35 AM   #184
besTint
Trader Rating: (81)
besTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the rough
Feedback Score: 81 reviews
Send a message via AIM to besTint
what is this front bumper??
http://squarespokes.com/
besTint is offline   Reply With Quote
Old 07-03-2010, 08:13 AM   #185
FullRaceGeoff
bumper is from touge factory - version select!
Old 07-03-2010, 03:30 PM   #186
besTint
Trader Rating: (81)
version 1 im guessing? and are they a replica company? cause version II is a picture of the MSPORTS kit.
Old 07-03-2010, 05:46 PM   #187
iwishiwas-all*
iwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfection
yes its a rep of vertex...
IG @gabednconfused
https://www.youtube.com/user/gabedm
iwishiwas-all* is offline   Reply With Quote
Old 07-06-2010, 10:53 AM   #188
FullRaceGeoff
beats me, i just liked it and got it cheap. good quality glass overall, it fit surprisingly well
Old 07-13-2010, 10:41 AM   #189
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
Hey Geoff got a job for me. Working at Mercedes Benz is starting to bore me and I know recession is a B!+ch but damn I would rather be a part of that.
redline racer510 is offline   Reply With Quote
Old 07-13-2010, 11:06 AM   #190
Bovi
Bovi's Avatar
Bovi is an unknown quantity at this point
sick ride !!!!
Bovi is offline   Reply With Quote
Old 07-13-2010, 12:07 PM   #191
niteridaz503
niteridaz503's Avatar
niteridaz503 is an unknown quantity at this point
Thumbs up
HOLLY FUDGE STICKS THIS THING IS AMAZING!!!!
I remember reading the whole article on this car, everything is absolutely incredible in this car its definitely an "AMAZING MACHINE"
Originally Posted by yetijeff View Post
Hes higher than giraffe pussy lolz
niteridaz503 is offline   Reply With Quote
Old 07-15-2010, 10:32 PM   #192
onlydrinkkoolaid
onlydrinkkoolaid's Avatar
onlydrinkkoolaid is an unknown quantity at this point
Originally Posted by fullracegeoff View Post
the new issue of modified magazine is on news stands, check it out!!
we got 2nd place in awd class.
full-race has recently received a lot of pms and emails now that the new issue of the tuner shootout is on newstands. The updated r14 portion of the full-race.com site is coming next week, but to answer the basic questions, ill copy/paste the beginning text for you:
Full-race.com -- r14 diy how-to info
this portion of the full-race.com website breaks down the r14 conversion in detail. Pictures and information help to make it clear how to do this awd rb26 swap. If you've done a few different motor swaps, installed some turbokits, know how to use a hand-drill + welder (220 volt mig welder recommended), and are committed/prepared to take on a big project you can tackle this install. If you dont know how to do swaps or install aftermarket turbokits, do not start this conversion until you have more experience or better understand the process.
A) required big parts:
-(95-98) s14 chassis, s15 will work too. S13 will not work for this swap!! <
-r32 gtr front clip w/ complete front suspension and complete rear subframe <easy to find at any big jdm importers/yards>
-full-race r14 diy kit
^^^if you can acquire all of the above items^^^ all the big purchases are out of the way.
B) full-race r14 kit consists of these parts required to do the swap:
R14 frame rails (left and right side)
r14 billet frame blocks
subframe bolts/washers
lhd rb26 steering rack
transmission mount
frame side transmission mount-plate
front upper-control-arm structure (upper shock mounts)
lower shock mounts
1-piece driveshaft (aluminum or steel)
1/2" eye-to-eye coilovers - moton or koni (circletrack or road race style heim-mounted)
here is how it all works, and enough instructions to get you going:
First, start by getting the r32 gtr clip fully disassembled. We will be using almost every major component from this clip. Keep all the suspension control arms, brakes, hubs and bolts sorted, with their respective hardware. The engine and transmission should be inspected and it is recommended to refresh it - new timing belt, clutch, oil pump, etc. At this point, the subframe should be unbolted from the motor mounts and then cleaned/prepped for the swap....
To be continued. Thanks for the interest in the r14 conversions!
please tell me more im just the kind of crazy person who would do this because its my dream to build awd s14 chassis
onlydrinkkoolaid is offline   Reply With Quote
Old 07-16-2010, 01:55 AM   #193
kognition
kognition's Avatar
kognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfection
This car is badass!
kognition is offline   Reply With Quote
Old 07-16-2010, 04:49 PM   #194
ItzGenX
ItzGenX is an unknown quantity at this point
This car is awesome! I am building an awd S14 right now also, but I am using the front shock towers from the R32 clip and R32 rear subframe instead of R33 rear subframe like the R14. Getting everything in and fitted seems to be no problem for me with the drivetrain. However, I am very interested in the torque split controller your friend is building. Got any new details on that? Lacking automatic torque split is the only problem I can see with the awd system being swapped in.
ItzGenX is offline   Reply With Quote
Old 07-16-2010, 04:52 PM   #195
ItzGenX
Hmm that name kognition rings a bell. You wouldn't happen to be the maker of sunroof deletes for S13/14's that I saw going around a while back but cant seem to find now would ya?
Old 07-16-2010, 06:12 PM   #196
ReaperBJJ
ReaperBJJ's Avatar
ReaperBJJ is an unknown quantity at this point
This car is one of my inspirations, once I get my new rustless s13 chassis I plan on going AWD once I figure out the whole Torque Split/Altessa delete issue. I've read up on plenty of s13's done and it doesn't seem like TOO much different, just lots of fab.
Also I couldn't find any interior shots really, do you have any?
ReaperBJJ is offline   Reply With Quote
Old 07-17-2010, 11:34 AM   #197
kognition
kognition's Avatar
No, im not that guy anymore. I had to stop making useless shit that wasn't making any money for the business.
Only track wings now.
Old 07-18-2010, 01:09 PM   #198
s!lv!a
s!lv!a is an unknown quantity at this point
this car is just so ridiculously nice, great work geoff
s!lv!a is offline   Reply With Quote
Old 07-21-2010, 11:45 PM   #199
onlydrinkkoolaid
If you dont mind me asking but where did you buy your spherical bearings from I have the welding skills just cant find anywhere to buy them from
Old 07-22-2010, 04:33 PM   #200
FullRaceGeoff
Originally Posted by kognition View Post
This car is badass!
^^^Best aero out!!!
The Kognition wing will help to balance out the chassis, especially with the NASCAR splitter setup we have. Currently - the POS wing we're using is about the same as an APR and just doesnt produce anywhere close to the amount of drag-free downforce a Kognition designed wing is capable of
to your work sir!
our web guy is a laggard! he's working on wrapping up an entirely new Full-Race.com site and the R14 update is part of that.
Originally Posted by niteridaz503 View Post
HOLLY FUDGE STICKS THIS THING IS AMAZING!!!! I remember reading the whole article on this car, everything is absolutely incredible in this car its definitely an "AMAZING MACHINE"
thanks alot for the props, the R14 is back under the knife getting a new turbokit and some aero love. you guys supporting us is huge motivation to keep things going!
i strongly encourage that you do the AWD swap with an S14! the S13 will be more work
SPLparts is the best quality nissan specific suspension parts that ive seen anywhere in the world.
if you are a fabricator and make your own arms or machine your own bearing housings, GMRstore the desert truck guys are no joke when it comes to sphericals and heims
Old 07-22-2010, 04:54 PM   #201
niteridaz503
you have it all wrong man your the motivation for us (if you catch my drift LMAO JK) leme know when you wana wax the R14 lol
This things intense and it just keeps getting better i wana see more updates & pics lol
Old 07-22-2010, 07:05 PM   #202
D1S13
D1S13's Avatar
D1S13 can only hope to improve
have you installed this kit on any customer cars?
www.teamtopflight.blogspot.com
D1S13 is offline   Reply With Quote
Old 07-22-2010, 09:00 PM   #203
Def
You sell the set of spherical bearings you got from me?
DEFSPORT
Old 07-23-2010, 10:51 AM   #204
FullRaceGeoff
yes, in fact thats where the pics for our installation guide came from One car in florida, one in georgia, one in the caribean, 2 in AZ and one in california. After these we just didnt have the time to bring cars in, because it was interfering with our turbokit mfg business
i ran them, however they developed way too much slop and i had to go back to the drawing board. Mike at skullworks was a help, but insisted his "Com" grade sphericals were up to the task... whatever the reason i have a bunch of those sphericals worn out by my desk. I switched to aurora motorsport grade and no problems.
Old 07-29-2010, 06:19 PM   #205
40cal
40cal is an unknown quantity at this point
what size bearings are you using?
are they 5/8 or 3/4 or bigger?
40cal is offline   Reply With Quote
Old 07-29-2010, 07:51 PM   #206
Future240
Future240's Avatar
This is the definition of car Pr0ns.
Originally Posted by ThatGuy
Future240 is online now   Reply With Quote
Old 07-30-2010, 03:23 PM   #207
FullRaceGeoff
thanks future240!
40cal, it depends on where the bearing is
Old 07-30-2010, 04:40 PM   #208
93sileighty
93sileighty is an unknown quantity at this point
Does this mean i missed something and these DIY kits are finally available or atleast have a firm date and pricing. If so I am now on a ramen and water diet and my turbo e34 project is officially scrapped because i will be building the r14 i have been dreaming about.
93sileighty is offline   Reply With Quote
Old 07-31-2010, 07:27 AM   #209
FullRaceGeoff
correct, the web guy we have is a terrible slacker and hasnt gotten anything done with our site as of late, but the DIY R14 kits are completely wrapped up with design work and install procedure. The pricing and web updates are all thats left. sorry to scrap your turbo e34 plans, but i have an i6 e39 i was going to boost and instead am building another r14 too
Old 08-05-2010, 10:08 PM   #210
onlydrinkkoolaid
please hurry with the site I have been on and off the page looking for updates since December 2007 when that Modified Mag issue came out and yes I still read that article from time to time. I thought you guys completed abandoned the R14 so i was left dreaming and quoting STAR TREK "to boldly go where no man has gone before."
full-race, gtr, r14, skyline, time attack
