Old 04-21-2008, 11:13 PM   #1
sxylaxplyr8
sxylaxplyr8 is making his/her stupidity well-knownsxylaxplyr8 is making his/her stupidity well-knownsxylaxplyr8 is making his/her stupidity well-knownsxylaxplyr8 is making his/her stupidity well-known
installing a cooling fan
So I have the fan and the relay but it seems like I'm missing some part. The fan only has two wires. One for power and the other to ground it. Or is it one wire to the sensor and the other to the power and needs no grounding? Any tid bit of info helps.
(O=O)/SR20DET\(O=O)
/_/oo\__________ __ \
sxylaxplyr8 is offline   Reply With Quote
Old 04-22-2008, 12:51 AM   #2
spoolandslide
hey one of my friends is having trouble with this and i dont know what to say
try looking at other threads
spoolandslide is offline   Reply With Quote
Old 04-22-2008, 01:20 AM   #3
spoolandslide
heres a diagram
http://www.aaroncake.net/rx-7/efaninstall.htm
Old 04-22-2008, 03:40 PM   #4
vanguard
vanguard is an unknown quantity at this point
Send a message via AIM to vanguard
put the ground into a relay in the fuse box under the hood. any fuse thats hot when the car starts will be sufficient to start the fan when the car does...the fuse box under your hood is also grounded pretty well so thats how it gets the grounding.... thats how i do my fans
vanguard is offline   Reply With Quote
Old 05-11-2008, 09:33 AM   #5
spoolandslide
did you get that taken care of man?
