Old 01-23-2012, 01:08 PM   #1
coupe92
coupe92 is an unknown quantity at this point
Boost gauge install help
I have a center vent pod for my boost and wideband gauges, but I don't know how to remove the center vents (yes I searched) and the frame that holds them, and don't know where to drill through to run the boost line without screwing something up.
Anyone else with center vent gauges that can share some knowledge? I've been boosted since september but still haven't got to properly installing this..The boost line is currently running out my hood and through my passenger window...
coupe92 is offline   Reply With Quote
Old 01-23-2012, 01:31 PM   #2
zspeedrft
zspeedrft's Avatar
Trader Rating: (54)
zspeedrft is an unknown quantity at this point
Feedback Score: 54 reviews
I ended up breaking mine...
zspeedrft is offline   Reply With Quote
Old 01-23-2012, 01:32 PM   #3
Walperstyle
Walperstyle's Avatar
broadfield, you seek broadfield
KA-T ORG-Function over Flush
Old 01-23-2012, 02:56 PM   #4
coupe92
I have the fins and the middle part of the vents out, but I don't have the actual surrounding frame that goes into the hole out. It is like the inner part that connects to the ac ducting. Still don't know where to drill.
Old 01-23-2012, 03:09 PM   #5
JDMRIDDAZ
JDMRIDDAZ's Avatar
JDMRIDDAZ is an unknown quantity at this point
u have to remove the vents and trim etc for it to fit properly
u can run the line thru the fire wall where engine harness comes thru
do not t from fuel pressure regulator
シチサn w/ka20det:in progress
シチサnw/sr20det:stolen
JDMRIDDAZ is offline   Reply With Quote
Old 01-23-2012, 03:49 PM   #6
w0nderbr3ad
Trader Rating: (50)
w0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to all
Feedback Score: 50 reviews
Send a message via AIM to w0nderbr3ad
You have to remove the dash to get that center vent out. Takes about an hour if you haven't done it before. Takes me about 15-20 min since I've pulled it out a couple of times to install gauges
w0nderbr3ad is offline   Reply With Quote
Old 01-23-2012, 03:59 PM   #7
coupe92
I have to remove the entire dash just to take out that little vent? damn, how do you get the boost line from where the harness goes through to the back of the gauge? Doesn't seem like a very direct route at all.
Old 01-23-2012, 04:49 PM   #8
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
Feedback Score: 82 reviews
I'll dO it for a fee
NEED Bolt kits for your car?
Old 01-27-2012, 07:26 PM   #9
freeagent3117
freeagent3117's Avatar
freeagent3117 is an unknown quantity at this point
You DO NOT need to take out the dash. WTF? There is four clips built into the duct. Two on top and two on bottom. The top ones you can get to with a screwdriver. The bottom ones dont need to be touched because once the top is out you can wiggle it out. I JUST did this last week for my gauges. Trust me. I did however break the gay trim ring lol.
Oh and just run the nylon hose where the ecu wiring comes in. Just tuck it in there and be careful pulling it through. Kinks easy!!
freeagent3117 is offline   Reply With Quote
boost, center, gauge, vent, wideband
