Old 10-23-2004, 06:10 PM   #1
dmora79
dmora79's Avatar
dmora79 is an unknown quantity at this point
265/17 or 18 all around on S14?
anyone have larger tires on their wheels for track events?
What kinds of wheels do you have, and were they custom offsets?
Any fender rolling?
dmora79 is offline   Reply With Quote
Old 11-01-2004, 03:45 PM   #2
dmora79
dmora79's Avatar
no one uses wider tires for track events?
Old 11-01-2004, 03:57 PM   #3
HaLo
from Canada, eh!
HaLo's Avatar
HaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfection
Send a message via ICQ to HaLo Send a message via AIM to HaLo Send a message via MSN to HaLo
AceInHole does.. 275/315 Hoosier combo.
-> HaLo
Race Car: '98 E36 BMW M3
Daily Driver: '08 Fiji Blue Honda Civic Si
SOLD: 01 GPW Honda S2000
PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET
SOLD: 93 Super White 240SX SE Convertible w/Silvia Front
HaLo is offline   Reply With Quote
Old 11-05-2004, 08:40 AM   #4
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
I run whats cheap and works.. 205 falkens all around on stock wheels.
I use the big wheels on the street for tha bling. :P
sykikchimp is offline   Reply With Quote
Old 11-05-2004, 12:58 PM   #5
dmora79
dmora79's Avatar
Thats quite a bit more than i was willing to do. Thats some major fender cutting and pulling.
Old 11-05-2004, 01:39 PM   #6
HaLo
from Canada, eh!
HaLo's Avatar
i use 225/245
-> HaLo
Old 11-05-2004, 02:15 PM   #7
98sr20ve
98sr20ve is an unknown quantity at this point
i use 225/245
Thats my street size. Still have not figured out the track size. I want the 245 all the way around. May need to use spacers to get that size to work in front.
Edit, this is on a s13 so I guess it does not help you.
98sr20ve is offline   Reply With Quote
Old 11-05-2004, 02:30 PM   #8
HaLo
from Canada, eh!
HaLo's Avatar
Exactly... i use that setup on my s13 for street and track... but I plan on 245 all around for track.. for an s14, go 275 all around!
-> HaLo
Old 11-05-2004, 02:37 PM   #9
nigel1
nigel1 is an unknown quantity at this point
thats kinda small......
nigel1 is offline   Reply With Quote
Old 11-05-2004, 02:37 PM   #10
HaLo
from Canada, eh!
HaLo's Avatar
it's small but it WORKS.
-> HaLo
Old 11-05-2004, 04:50 PM   #11
carnal_c30
carnal_c30 is an unknown quantity at this point
I use 235/45-17 and 265/40-17 on 17x8 17x9 no cutting required on an s14 offset front- 28 offset rear, 35
carnal_c30 is offline   Reply With Quote
Old 11-07-2004, 02:02 PM   #12
ghostuss
ghostuss is an unknown quantity at this point
Send a message via AIM to ghostuss
So hard for me to break traction with 225/245 50s. I want to break traction so hehe gonna go with something different on the track. 225/225 maybe
96 all suspension s14 SOLD
90 s13 coupe - SOLD
Currently rocking 2002 BMW M3 w/ custom suspension.
ButtonWillow, CA entire circuit drift/grip event by shock drifting spot for sale. Take over my spot for $150 only.
ghostuss is offline   Reply With Quote
Old 11-08-2004, 05:22 PM   #13
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
275 on the front with: 17x9 wheel +27 offset. 3/4" spacer.
Fenders pulled *slightly* to clear, but Hoosiers are a bit wider than rated.
Running a 265 up front should be fine w/o major pulling using the right offsets. I ran 245's up front with stock fenders for a year without probs. Used a rim sized 16x7.5 +26mm. Plenty of clearance to the fender and coilover.
245/45/R16 worked great for me for autocross. It should work great for the track as well. With a 240sx, you really don't NEED much more tire than that untill you start making huge HP numbers. I'm gearing my setup to push around 350 to the wheels, which is why I run the huge tires... but looking back, i probably should've gone 275 on all 4 corners. The rear tires just aren't getting a lot of heat into them, so I'm not even maximizing my grip just yet.
AceInHole is offline   Reply With Quote
Old 12-03-2004, 08:36 PM   #14
theicecreamdan
I dont have much trouble spinning my yokohama advan 235/45/17 in my KA s14, but they are pretty bald now and I got some cheap 255 40 to put on the rears next week.
theicecreamdan is offline   Reply With Quote
Old 12-05-2004, 01:29 PM   #15
AzNCmB
AzNCmB's Avatar
AzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond repute
Send a message via AIM to AzNCmB
What do you guys think about 255/40 or 245/40's on 17x9 24mm cobra rims, for the rears of a stock s14?
thanks in advance.
AzNCmB is offline   Reply With Quote
Old 12-08-2004, 02:35 PM   #16
nlzmo400r
nlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nice
Send a message via AIM to nlzmo400r
well kim, since your car is pretty much stock,i dont think you'll need any wider than a 245 for sure. It'll look awesome, what are you running in the front?
'my drinking team has a racing problem'
[email protected] - gt32 .6bar
nlzmo400r is offline   Reply With Quote
