04-18-2012, 09:37 AM | #1 |
Redtop sr20det bolts for coil broke
Wassup Zilvians, a genius friend of mine overtorqued the bolt holding down the coil on cyl #3 does anyone have the part number for this bolt or measurements so I can order another one? Thanks!!
04-19-2012, 04:54 AM | #4 |
You can still do that, with the other bolts you have. If you have a tap and die set, you could measure. thread pitch, diameter and length. or go to home depo and use their tool to get said measurements.
LoverTechnologies "Half Broken Things!" |
04-19-2012, 05:54 AM | #5 |
the coil bolts are not sold separately. So like the other guy said you'll have to find something similar and pick it up at vatozone.
Wayne |
