02-05-2012, 09:24 PM | #61 | |
12-04-2016, 08:58 PM | #62 |
Bumping this to add that in my research a lot of evidence (i.e. people using vacuum gauges) suggests the back pressure of the exhaust under boost prevents scavenging. I'm going to be running my catch can line preturbo.
12-04-2016, 10:21 PM | #63 |
Anecdotally my friend who is 100% performance oriented did a slash cut and said he had adverse effects, I will ask him what he encountered.
MRP Manufacturing |
12-05-2016, 12:16 AM | #64 | |
I have not put a gauge on my exhaust line/CC to see an actual number, but I can tell you at idle I have decent vacuum on the system. I'll be glad to swing by and let you listen to the air release when the dip stick is pulled out at idle.
My SR20VET |
12-05-2016, 06:24 AM | #65 | |
I might take you up on that. I'm rebuilding my SR right now and I'm wanting to get the best seal possible as I wear in the new rings. A few years ago I read about using the exhaust to pull vacuum and it seemed like the best method however checking again now it seems that it doesn't do so well under moderate / high loads. |
12-05-2016, 07:44 AM | #66 |
Just shoot me a pm if you want to meet up.
Here is the correct orientation required for vacuum. If it's positioned the opposite way, it will not function properly. This isn't new tech by any means. Drag racers have been using this for decades.
My SR20VET |
12-05-2016, 09:39 AM | #67 |
whether or not this set up will work for your car GREATLY depends on the exhaust on your car and for 90% of cars it will not work as the exhaust DOES get back pressure that is not over come by the vacuum created from these.
Its not that hard to set up and test your self though so if your considering it just give it a go and T in a MAP sensor or boost gauge and report back. *you'll see + * |
12-05-2016, 10:36 AM | #68 |
Yes, backpressure is present, but the exhaust velocity is what causes vacuum on the catch can. Is that back pressure enough to force closed the check valve vs the suction pressure created by the Venturi? That would be the question to ask. Is the differential pressure across the check valve/Venturi enough to create flow? Dyno numbers have proven this works, I'm not sure why there is so much skepticism.
My SR20VET |
12-05-2016, 04:18 PM | #69 |
The only time ive seen this done, is when blowby is high and they get tired of dumping the catch cans, its just hiding the problem with rings. A properly plumbed catch can setup doesn't involve running anything to your exhaust.
12-05-2016, 04:25 PM | #70 |
It's no different than running in to the turbo suction, just like a factory setup...
My SR20VET |
12-05-2016, 04:28 PM | #71 |
You could have a catch can ran to the exhaust even lol.
Weird, I figured the orientation of that valve would have been the other way, with the opening facing down stream. Interesting. |
12-05-2016, 05:27 PM | #72 |
This is true, but on the ragged edge of tuning any oil vapor will decrease your effective octane rating, you won't see that happen with an exhaust ran evacuation point
MRP Manufacturing |
12-06-2016, 08:22 AM | #73 |
IMO you shouldn't be on the ragged edge unless the car has sponsors, free engines, and is a serious race car. And Those cars will get vacuum pump, dry sump.
Probably need something with more resolution that a map sensor or boost gauge for PCV related activities. A gauge/sensor which renders 32"~ of H2O (WATER) on a data-logger would be ideal. |
12-07-2016, 12:29 AM | #74 |
While I do get that using some neat little effects of fluid dynamics it is conceivable that you could create a lower pressure in the exhaust line than exists in the crankcase. I do not understand why anyone would consider it for more than a split second when you have a constant source of vacuum while the engine is running at the intake. I mean maybe in a crazy all motor ITB build that doesn't always pull vaccum, but FFS just get a quality catch can with good filtration and you are done. Plumb the drain hole at the bottom into the dipstick tube, or turbo return line, and you don't even have to check/drain the thing. Not that most people on here need anything more than the factory one that came on SRs.
'89 hatch DD'd SR'd 2871'd - Sold 2006 Legacy GT Wagon |
12-07-2016, 02:25 AM | #75 |
Trader Rating: (82)
Feedback Score: 82 reviews
I have a ka24de-t and on the stock pcv box location I simply welded a 10an fitting and ran a hose to my downpipe with a check valve. It's a moroso unit cost about 30 dollars , you must get the pipe that has a cut out , to weld it to your downpipe
NEED Bolt kits for your car? |
12-07-2016, 05:44 AM | #76 | |
Yes, suction at the turbo is a good constant source, but not everyone has an intake pipe, let alone a filter mounted to their turbo. I plumbed mine to the exhaust because I didn't want the contaminated oil vapor sucked into the turbo and essentially puked into the intercooler, plumbing, sensors, and eventually motor. What you're sucking out of the motor is nasty shit and it will gum things up over time.
My SR20VET Last edited by jr_ss; 12-07-2016 at 07:18 AM.. |
12-13-2016, 12:06 PM | #77 |
I emptied my catch can today. It hasnt been done in awhile and this was the result. Green tint/hue is from the Brad Penn motor oil I use. I'd say my exhaust evac is working just fine...
My SR20VET |
12-14-2016, 11:54 PM | #78 |
if I were running an exhaust driven PCV system without monitoring, I would incorporate a check-valve breather, such that during boost the system would default to open atmospheric (no pcv action) if there were any pressure, since I would also be using a quiet exhaust system (probably high back pressure). Back to normal driving and the exhaust driven system does the crankcase vacuum as if it were on the intake manifold, this way oil would never see the intake valves no matter what and any positive pressure that the exhaust driven setup couldn't deal with would exit via check valve (because I weren't monitoring it to know for sure). There is a guy on LS-1 tech "Mighty Mouse" promoting a similar setup, and after considering it, I agree this is a fair compromise on a high performance engine without crankcase monitoring refinement.
Oil may be collecting during normal driving, and none during WOT. Without a gauge on the crankcase, there is no way to monitor what is really happening. Also, oil vapor (as single, gas state molecules) might work its way into a tube and collect there (hydrophobic interactions) without any help from pcv systems (could be at any pressure around atmospheric). |
12-15-2016, 09:00 AM | #79 |
While I'll agree that it could be from normal driving, back pressure is present while the car is running, only in varying amounts. With that said, so is exhaust velocity.
My SR20VET |
