Old 08-16-2008, 01:16 AM   #1
boosted98gst
boosted98gst has a brilliant futureboosted98gst has a brilliant futureboosted98gst has a brilliant futureboosted98gst has a brilliant futureboosted98gst has a brilliant futureboosted98gst has a brilliant futureboosted98gst has a brilliant futureboosted98gst has a brilliant futureboosted98gst has a brilliant futureboosted98gst has a brilliant futureboosted98gst has a brilliant future
Send a message via AIM to boosted98gst
240sx coupe fender pulling issues.
This is one thing that I really do not know well, I bought a coupe and its had its fenders rolled and pulled, its about a 2 inch pull or so and they did a really crappy job, metal work is not one of my good trades so im taking the car to a body shop to be re worked and look perfect, I am really anal about it. When the cars gets back I am going to post a step by step process on zilvia how to paint your car decent with out spray bomb and using good paint like dupont or ppg either way, here is my question what common set of wheels will look good filling the pull? I am not a tire freak like the guys in the wheel thread, but just somthing that does not look stupid I only have around 2,000 total to spend on rims which is not much I know but its going to have to do. I just want somthing decent like work emo kai or xd9's wouls the 9.5's be enough to fill up the space? fill me in. thanks for the space.
I will try and find a pic of someone on here with a close pull so you can get an idea. thank you.
boosted98gst is offline   Reply With Quote
Old 08-16-2008, 01:35 AM   #2
i8yourfwd
i8yourfwd's Avatar
i8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfectioni8yourfwd is close to perfection
Send a message via AIM to i8yourfwd
There is a wheel fitment thread.
http://zilvia.net/f/chat/129865-whee...re-thread.html
Cmon, on here for 2+ years and you can't find the wheel fitment thread?
http://jaythroughglass.blogspot.com
S13SilviaGirl: Mel are you that big?
i8yourfwd is offline   Reply With Quote
Old 08-16-2008, 01:40 AM   #3
boosted98gst
I know the wheel fitment thread it said I already looked in my first post.
Old 08-16-2008, 01:42 AM   #4
i8yourfwd
i8yourfwd's Avatar
So what exactly is the question? Do you not want to stretch tire or something? There was also a max rubber thread too somewhere
Also, if you're not 5 lug, your wheel selection will be very limited :/
Old 08-16-2008, 01:45 AM   #5
boosted98gst
Yes i checked it also, how would I go about measuring to find out the correct offset for the pull? I wanted to stay with an entry level rim somthing cheap like works entry rim. My issue the pull is alot bigger then I thought and did not want to get into somthing wider ect ect, is there a proper way of measuring the correct way?
Old 08-16-2008, 01:46 AM   #6
boosted98gst
of course my car is 5 lug .
Old 08-16-2008, 01:47 AM   #7
boosted98gst
I can deal with a mild streted tire, im more worried about my pull being too much for a rim.
Old 08-16-2008, 01:48 AM   #8
i8yourfwd
i8yourfwd's Avatar
Not really, I mean I suppose you can eyeball and measure how much it's pulled out, compare it to stock. Then go from there, choosing your offset/width.
http://zilvia.net/f/2251141-post1965.html <-slight pull, s13 coupe, to give you an idea.
But hey, if it's not quite as flush as you'd like it in the end, there's always spacers right?
Old 08-16-2008, 01:54 AM   #9
boosted98gst
See I would be happy with that pull and rim and tire set up, my pull is a little more and thats a 10.5 inch rim im not sure what im going to do.
Old 08-16-2008, 02:24 AM   #10
i8yourfwd
i8yourfwd's Avatar
Maybe take a pic of your pull, and see if anyone else will have any input?
Old 08-16-2008, 03:04 AM   #11
boosted98gst
Thanks what I will do.
Old 08-16-2008, 01:46 PM   #12
boosted98gst
anyway someone can help me out and let me send the pic onto their phone, thats the only cam i have, if so just pm me your number and i will send it and you can post it up for me.
