Old 07-30-2009, 09:21 PM   #1
Import_Prophetz
Import_Prophetz's Avatar
Import_Prophetz has a spectacular aura aboutImport_Prophetz has a spectacular aura aboutImport_Prophetz has a spectacular aura aboutImport_Prophetz has a spectacular aura aboutImport_Prophetz has a spectacular aura aboutImport_Prophetz has a spectacular aura about
17x9 front wheels RUB?
Do 17x9 Front wheels rub even with tien coilovers? I heard they his the top perch and I would need 15mm Spacers. Has anybody done this, and not need spacers?
Import_Prophetz is offline   Reply With Quote
Old 07-30-2009, 09:24 PM   #2
blackrms13
blackrms13's Avatar
blackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfection
Send a message via AIM to blackrms13
need to know the offset...
91' 240sx Fastback LE
blackrms13 is offline   Reply With Quote
Old 07-30-2009, 09:27 PM   #3
Import_Prophetz
I want to say +35. Bad offset, and before I get knocked I know I coul have hit the search button. I was lazy, wont happen again.
Old 07-30-2009, 09:58 PM   #4
w0nderbr3ad
Trader Rating: (50)
w0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to all
Feedback Score: 50 reviews
Send a message via AIM to w0nderbr3ad
I have about 5mm of space between my coilover and my inner lip. I'm on 17x9 +17 running -3 camber. If you're rubbing just get a spacer or another set of wheels.
w0nderbr3ad is offline   Reply With Quote
Old 07-30-2009, 11:34 PM   #5
slo_slideways
slo_slideways's Avatar
slo_slideways is an unknown quantity at this point
With a positive offset like 35 or so you may need a 10-15mm spacer. If your running like +20 or less you should be good.
REPPIN' NORCAL HARDER THAN HERSHEY'S TURTLE SHELL CHOCOLATE SHIZ!!!
slo_slideways is offline   Reply With Quote
Old 08-03-2009, 01:52 PM   #6
Import_Prophetz
I was thinking about 15mm spacers, But dont I need to get extended studs?
Old 08-03-2009, 02:07 PM   #7
BigVinnie
BigVinnie's Avatar
BigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfection
If your car is an S14 you will need a 10mm spacer, and extended studs.
If you have an s13 you will need a 8mm spacer, no extended lugs needed.
How do I know this? Because I have the sprt MAX 962 rims on my s13, and s14.
BigVinnie is offline   Reply With Quote
Old 08-03-2009, 02:18 PM   #8
JAYTRON
JAYTRON's Avatar
JAYTRON is making a name for him/her selfJAYTRON is making a name for him/her self
Send a message via AIM to JAYTRON
Just spend a little more and buy 25mm spacers.
Most come with extended studs and screws for your original studs.
Like above.
And to top it off, you'll probably regret not getting 25mm if you buy 15mm
because most people end up wanting a bit more "poke"
JAYTRON is offline   Reply With Quote
Old 08-03-2009, 04:00 PM   #9
Sileighty_85
Sileighty_85's Avatar
around +20 will be fine
this is my 18X9.5+20 with NO spacers on an S13
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html
Old 08-03-2009, 04:39 PM   #10
venom_5
venom_5's Avatar
venom_5 is an unknown quantity at this point
17x9+22 dont rub on an S14 with Eibach Sportlines on KYB GR-2s, since you have coilovers you will have more inside clearance so id say a +35 shouldnt rub but theres only 1 way to be 100% sure
RIP: 95 "Slamry" | Welcome: "Blurple" 96 240SX SE
venom_5 is offline   Reply With Quote
Old 08-03-2009, 06:13 PM   #11
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Shocks and springs /= coilovers.
The lowest offset you can go on an s chassis with coils and 9" wheels is a 17x9 +25-22.
That's getting lucky, it also depends on how you have your preload set up.
Old 08-03-2009, 06:17 PM   #12
JRwerks
JRwerks's Avatar
Trader Rating: (55)
JRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of light
Feedback Score: 55 reviews
i run a 17x9.5 +15 with a 235/45 tire in the front ... fenders are not rolled or pulled and i clear fine
JRwerks is offline   Reply With Quote
Old 08-03-2009, 06:41 PM   #13
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Pics of your car and ride height would be important here.
I find that hard to believe since I had an S13 with 17x9 +12 (5mm spacer) with a 215/45/17 and it rubbed when turning.
See the tire on the fender?
You can see smoke from the tire rubbing.
Old 08-03-2009, 11:57 PM   #14
Import_Prophetz
Nice viper. Thanks, I actually have the sportmazz 962's. Also I have the Rota Grid +15 offset 16x8. I have some volks te37's but they dont look great. Thanks guys. I will try the 8mm studs first. The rear I am putting a widebody on, So I will need some spacers back there. Thanks.
Old 08-04-2009, 02:23 AM   #15
blackrms13
blackrms13's Avatar
+35 offset on a widebody?
erghhhhhhhhhhhhh
and im pretty sure Grids are +10mm not 15mm
Old 08-04-2009, 10:24 AM   #16
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
on my s13. stock fenders. front wheel - 17x9.5 +14 and also 17x9 +4 or something.
on my S14. stock fenders. front wheel - 17x9 +-0
I rubbed some tire on the fender here and there, but then again, the cars were low.
http://bhworld.wordpress.com/
Old 08-04-2009, 10:41 AM   #17
Devil Man
Devil Man is an unknown quantity at this point
thats a noble not a viper.
i rock 17x9 +22 with a 10mm spacer and i have no rubbing issues.
not to be a dick, but to be a dick....
Devil Man is offline   Reply With Quote
Old 08-04-2009, 11:09 AM   #18
8Nismo9
8Nismo9's Avatar
8Nismo9 will become famous soon enough8Nismo9 will become famous soon enough8Nismo9 will become famous soon enough8Nismo9 will become famous soon enough8Nismo9 will become famous soon enough
Send a message via AIM to 8Nismo9
Like above.
im using those,i still rubbed but that was the inner linear,also rolled my fenders.17x9 +35 all around
8Nismo9 is offline   Reply With Quote
Old 08-06-2009, 08:48 PM   #19
Import_Prophetz
Grids are +15, Custom for my AE86, but I am selling my AE86 soon. I just decided to widebody, and convert the front to s15. Since I sold my MK4 supra I am kinda depressed. That gives me the excuse to work on one of my cars.
Old 08-06-2009, 09:27 PM   #20
Import_Prophetz
Went to check Rota's, your right +10 offset, sorry.
Old 11-26-2009, 01:57 PM   #21
cole d
cole d is an unknown quantity at this point
I got a questions for you guys I contemplating rota grid's 18x9.5 +20 all around would that clear springs and agx shocks on a s13?
cole d is offline   Reply With Quote
Old 11-26-2009, 04:03 PM   #22
!Zar!
!Zar!'s Avatar
There aren't really any clearance issues with shocks and springs.
Coilovers are what you need to watch out for.
Old 11-27-2009, 04:07 AM   #23
mptjimmy
mptjimmy is an unknown quantity at this point
if you have megan coilovers, they have extended lower brackets,
http://www.meganracing.com/demo/prod...=588&catid=105
mptjimmy is offline   Reply With Quote
Old 11-28-2009, 08:47 PM   #24
cole d
So, I can get a 18x9.5 +20 on the front of a s13 with shock and springs without a clearance issues?
Old 12-24-2009, 06:20 PM   #25
1gr8bar10der
1gr8bar10der's Avatar
Trader Rating: (77)
Feedback Score: 77 reviews
I'm about to put 17x10 +25 on mine with coils.
1gr8bar10der is offline   Reply With Quote
Old 12-24-2009, 06:58 PM   #26
cumbewong
cumbewong is an unknown quantity at this point
Send a message via AIM to cumbewong
I'm goin to be buying 18x9.5 +35 wheels. do i need spacers? and if so, what mm?
thankss
cumbewong is offline   Reply With Quote
Old 12-24-2009, 07:00 PM   #27
wiggafly808
wiggafly808's Avatar
wiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to allwiggafly808 is a name known to all
I have tein hrs and sportmaxx 962 17x9s as well.
25mm spacers, 25mm overfenders, and i dont rub (front coils all the way down).
I did need 15mm spacers to clear the coils, but opted to go 25 so i wouldnt have to change my studs.
Heres a pic:
wiggafly808 is offline   Reply With Quote
Old 12-24-2009, 08:07 PM   #28
LayNLow
LayNLow is making a name for him/her selfLayNLow is making a name for him/her self
Heres a pic:
Um, so whats the offset on the whees?
LayNLow is offline   Reply With Quote
Old 12-24-2009, 08:24 PM   #29
nismo racer
nismo racer's Avatar
nismo racer is making a name for him/her selfnismo racer is making a name for him/her self
right now im running 17x9 spaced out to +4 with -3 camber with just a roll and i rub but not that bad only on full lock is when i rub. its flush on the fender oh and my coils are maxed out low with two collars on each side on the fronts. when i had them at 17x9 et 24 i didnt have any clearance issue with my coils.
PEGASUS
nismo racer is offline   Reply With Quote
Old 12-24-2009, 10:50 PM   #30
lilrusty
lilrusty's Avatar
Trader Rating: (37)
lilrusty is an unknown quantity at this point
Feedback Score: 37 reviews
im running 17x9 +28 with 235/40 up front and i dont rub at all....
lilrusty is offline   Reply With Quote
