Old 02-10-2010, 02:34 PM   #1
fufanu180
fufanu180's Avatar
fufanu180 is an unknown quantity at this point
s13 Font End Problems!
Alright, I have a 1990 240SX and when I'm stationairy and have to turn the wheel there's something that pops. It drives me insane and I can't seem to figure out the problem.
If I could just get some input from you guys that would be great.
I've been under the car quite a few times working on the suspension and installing polyurethane bushings but I still haven't pin pointed the problem yet.
Thanks in advance.
fufanu180 is offline   Reply With Quote
Old 02-10-2010, 02:43 PM   #2
mmdb
mmdb's Avatar
mmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymore
I'm going to take a stab at it and say it's the sway bar endlinks binding.
.25 till 3
mmdb is offline   Reply With Quote
Old 02-10-2010, 02:53 PM   #3
fufanu180
fufanu180's Avatar
That's a good place to start. I'll check them out and see.
Are sway bars one of those components that if they aren't really wrenched down then they make all sorts of noises?
Old 02-10-2010, 02:59 PM   #4
WIKID S4TEEN
WIKID S4TEEN's Avatar
WIKID S4TEEN is making a name for him/her selfWIKID S4TEEN is making a name for him/her self
Maybe your spring/coil???
If you turn your steering faster, does it sound louder?
Rock wha U jock and don't talk if U ain't got!!
WIKID S4TEEN is offline   Reply With Quote
Old 02-10-2010, 03:05 PM   #5
D.Adams
D.Adams's Avatar
i would start here. my old OEM coils poped everytime i turned my wheel.
“About the time we think we can make ends meet, somebody moves the ends.” ―Herbert Hoover
The build
http://zilvia.net/f/builds-builds-on...u-city-az.html
Owner of NVS Fabrications
Old 02-10-2010, 07:50 PM   #6
fufanu180
fufanu180's Avatar
I'm not too sure if it sounds louder. I'll have to check it. I have an eibach pro kit on the car, but anyways, if it ended up being the coils what would I need to do to fix it?
Old 02-10-2010, 09:12 PM   #7
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
when you install springs on a shock there is usually a little bump stop, kind of a notch in the bottom where the end of the spring would rest against.
if the gap itll make a popping nose when turning the wheel. had that on my sentra after i installed HR springs.
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 02-10-2010, 09:17 PM   #8
WIKID S4TEEN
Did you recently take the strut/coil apart?
It may not be assembled properly.
The "spring seat" (top plate/hat) is allowing the coil to move around.
I would take it apart and reassemble and/or check if its loose.
Old 02-11-2010, 02:41 PM   #9
fufanu180
fufanu180's Avatar
I weill definitely check the strut/coil now. I haven't taken them apart but they are aftermarket so it could possibly be that the guy before me just didn't put them in apart.
Thanks a lot guys, I was thinking it could be the steering rack or pinion maybe.
