Old 04-08-2013, 12:04 PM   #1
[email protected]@t!c
SX-f@n@t!c's Avatar
SX-f@n@t!c is an unknown quantity at this point
s13 electrical problem!! help!
Ok so I've been scratching my head at this for 2 days now and can't seem to find the solution maybe some of you can help at least with a diagnoses so I can fix this.
So my car was starting fine with no problems..and then all of a sudden I lost power inside the cabin ingnition won't even turn on the gauges, windows don't go up, sunroof doesn't either!? And the weird part is that my headlights still function fine the pop ups still go up?
We tried jump starting it, push starting it, switched out the battery, checked all the fuses and relays and they're all good!? So idk what else could possibly go wrong?
So if any body can help it would be great! This is my only daily and I need it to get to work so I need it running asap!
S13 coupe Sr20det
SX-f@n@t!c is offline   Reply With Quote
Old 04-08-2013, 12:31 PM   #2
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
How low is your car? sounds like something got rubbed thru or disconnected.
how is the driver side harness in your wheel well?
Z32 with lq4 swap
Desert Street Scene || Dssevents.com
ultimateirving is offline   Reply With Quote
Old 04-08-2013, 12:50 PM   #3
SX-f@n@t!c's Avatar
Yea I just recently lowered my car pretty low! So let me check that harness
S13 coupe Sr20det
Old 04-08-2013, 02:57 PM   #4
itz matthew xP
Location: NYC if i tell you anymore i will need to kill you!
itz matthew xP is an unknown quantity at this point
Should be the harness that sits above the wheels, take your fenders off and move the harness up into the fender.
itz matthew xP is offline   Reply With Quote
Old 04-08-2013, 03:00 PM   #5
ryandriftingfat
ryandriftingfat's Avatar
ryandriftingfat is an unknown quantity at this point
Do this: Help, my tire is eating through my harness!
Driver side is usually the issue but check the passenger side fender well - there is a harness in there too.
WYLD STALLYNS
http://instagram.com/ryandriftingfat
ryandriftingfat is offline   Reply With Quote
Old 04-09-2013, 07:36 PM   #6
SX-f@n@t!c's Avatar
Ok so I figured out the problem and it seems to be at the fuse box..the wires leading the the fuel pump and eng. Cont. Fuses are burnt and not passing any current. Is there any way I can patch the wires up since they're burnt right where they connect to the fuse box? Or do I have replace the entire fuse box and harness??
As far as the harness under the wheel wall, it was fine but I'm definitely going to relocate that before it causes a problem as well.
S13 coupe Sr20det
