Old 10-11-2015, 02:12 PM   #1
Coppo
Coppo is an unknown quantity at this point
R33 r200 into S13
Hey guys, got a SR20DET S13 with a fairly shit diff, bought my mates R33 diff to put into it as its a LSD.
Just wondering what I'd need to make it work, I'm assuming that its been done before,
Thanks.
Coppo is offline   Reply With Quote
Old 10-11-2015, 05:24 PM   #2
LivelyZ
LivelyZ is an unknown quantity at this point
Thanks.
From what I've found is it will fit perfectly in the subframe and bolt right up as theyre the same?
edit: not 100% sure on it though.. If the axels are different you may have to remove the stub shafts of your old differential and place them in your new one and use the old axels if theyre different # of bolts..
edit 2: may have to change the rear cover and the front ears could be bigger on the R33 diff. Other then that.. R200 is used in many models.
edit 3: Also, driveshaft lengths may vary if going from abs to non abs
'97 sr20det swapped Kouki
previous: 94 Supra, 04 WRX
LivelyZ is offline   Reply With Quote
