Old 10-19-2017, 08:32 AM   #1
ciriello16
ciriello16 is an unknown quantity at this point
s15 S15 brake pads and rotors confusion
Hey so I have a 1999 s15 spec r and I'm in need of some brake pads and rotors, the issue I'm having is living in Canada is hard to get rhd car parts other than going on ebay and waiting 3 weeks for overpriced aftermarket parts when it's just a daily street car. I'm aware that the S15 use a 4 x 40.4mm Piston Sumitomo front caliper, same as Z32 so I'm assuming the pads and rotors are going to be the same but my issue is with the rear if the fronts are ok. Would anyone be able to tell me what vehicles share brake pads that would fit. I've searched the forums but I see mixed answers and not solid facts. Thank you.
ciriello16 is offline   Reply With Quote
Old 10-20-2017, 01:06 PM   #2
LoSt180
LoSt180's Avatar
Trader Rating: (18)
LoSt180 is an unknown quantity at this point
Feedback Score: 18 reviews
Front is the same as Z32 pads & rotors. Rear will be the same as late model S14.
JDM S14s had the same setup.
LoSt180 is offline   Reply With Quote
Old 10-27-2017, 10:26 AM   #3
ciriello16
late model s14 meaning 240sx around 1998 1997?
Old 10-27-2017, 01:05 PM   #4
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Yes, that's correct.
Rear rotor and pads are the same as a 97/98 240SX SE (w/ 5 lug): rotor is 258mm x 9mm
Front, again, is same as 91+ 300ZX: rotor is 280mm x 30mm
Old 10-27-2017, 01:34 PM   #5
ciriello16
thanks a lot, I appreciate it!
Old 11-10-2017, 12:36 PM   #6
cespana
cespana's Avatar
cespana is an unknown quantity at this point
As emergency, you also could use 4pot 4Runner/Tacoma brake pads for your calipers.
cespana is offline   Reply With Quote
Old 11-13-2017, 03:57 AM   #7
gaz_moose
gaz_moose is an unknown quantity at this point
pretty much all 4 pot Nissan front pads are the same, r32 gtst/gtr r33 gtst/gtr z32 s14 s15 Subaru with sumito calipers.
an s15 is basically the same as a UK / jap spec s14 suspension and mostly engine wise.
gaz_moose is offline   Reply With Quote
s15 300zx z33 brake pads
