Old 05-01-2005, 11:09 AM   #1
AN89HATCH
AN89HATCH is a well-known jackass
o2 sensor wire question
on my engine harness, my 02 sensor wire seems to have goten a cut on it, and some of the wires seemed to have seperated, so i tryed to soder them togeather hopeing that will fix it, my car feels normal, but im wondering if i will passs smog, since i have to get my car smoged nex week, can this cause a problem? Is there any way to replace that whole wire? ( imm talking about the wire that connect to th 02 sensor form the engine harness)
slide your ride.com
AN89HATCH is offline   Reply With Quote
Old 05-01-2005, 11:20 AM   #2
Ritz S14
Ritz S14's Avatar
Ritz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud ofRitz S14 has much to be proud of
Make sure your check engine light is not illuminated while you drive, then you should be okay. Also, wrap electrical tape around the exposed wire so that it doesn't ground out.
Ritz S14 is offline   Reply With Quote
