Old 04-22-2008, 02:49 PM   #1
cooldill
cooldill is a glorious beacon of lightcooldill is a glorious beacon of lightcooldill is a glorious beacon of lightcooldill is a glorious beacon of lightcooldill is a glorious beacon of lightcooldill is a glorious beacon of lightcooldill is a glorious beacon of lightcooldill is a glorious beacon of lightcooldill is a glorious beacon of lightcooldill is a glorious beacon of lightcooldill is a glorious beacon of light
KA24de shakes
I just bought this car 2 days ago, car is a 93 auto. today when i started it, the engine light came on and it shakes pretty hard while in drive. While in park and in neutral its fine. The car idles fine, just shakes and feels like its gona die. I pulled out the plug wires and the ends were moist with what smelled like coolant? the ends were also crusty and rust colored. I just moved here from hawaii and i dont have any of my tools with me. Im gonna go buy some new tools so i can check the plugs and such. but anyone have any ideas?
cooldill is offline   Reply With Quote
Old 04-22-2008, 03:07 PM   #2
Sr20det>Ka24de
Sr20det>Ka24de's Avatar
Sr20det>Ka24de is not welcome here anymoreSr20det>Ka24de is not welcome here anymoreSr20det>Ka24de is not welcome here anymoreSr20det>Ka24de is not welcome here anymoreSr20det>Ka24de is not welcome here anymoreSr20det>Ka24de is not welcome here anymoreSr20det>Ka24de is not welcome here anymoreSr20det>Ka24de is not welcome here anymoreSr20det>Ka24de is not welcome here anymoreSr20det>Ka24de is not welcome here anymoreSr20det>Ka24de is not welcome here anymore
KA
sounds like water in the plug holes that has been there awhile, used compressed air to dry out plug holes and wires if your are gonna keep the wires. If your plugs are rusty replace em, replace wires too they are probably old any how
minitrucker - 240 addict, now how to combine them?
Sr20det>Ka24de is offline   Reply With Quote
Old 04-25-2008, 01:24 AM   #3
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
the plug wires or the plug? if its the plug wires.. just slip the connection off the rubber and dry it with a towel or air... pull ur spark plugs and look at them what color black, white ? check ur maf and make sure its plugged in and working.. if engine is having problems under load... you might have some other issues... be a little more descriptive... might want to do a quick tune up.. and check the oil. what color is it? typical or milky? coolant also do u have brown stuff floating in it?
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 04-25-2008, 01:27 AM   #4
Xandy Boosts
Xandy Boosts's Avatar
Xandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfection
Send a message via AIM to Xandy Boosts
My car shook ALOT and pretty hard when I blew my headgasket.
it's a RUCKUS life
Xandy Boosts is offline   Reply With Quote
Old 05-03-2008, 08:28 AM   #5
richesmoua
richesmoua is not welcome here anymorerichesmoua is not welcome here anymorerichesmoua is not welcome here anymorerichesmoua is not welcome here anymorerichesmoua is not welcome here anymorerichesmoua is not welcome here anymorerichesmoua is not welcome here anymorerichesmoua is not welcome here anymorerichesmoua is not welcome here anymorerichesmoua is not welcome here anymore
I just bought my 90 auto. 240sx and it did the same thing. After a couple of days we figured out the problem. The owner before had switch the spark plug wires around, plus the shaking part was due to bad injectors and the wire that connected from the wire harness to the injector(don't know what those are called), but the shaking was from the injector connectors because when I twitch the wires a little it will run perfect, but if I push down on them the car will shake a lot and sound like it will shut down instantly. Oh k the real problem was 2 bad injectors...take your injectors out and look at them you may have some cracked and some burned out!
richesmoua is offline   Reply With Quote
