Old 08-19-2010, 04:18 PM   #1
The408silvia
The408silvia is an unknown quantity at this point
s14 Need some help!!! Bad shaking...
Hey whats up all?
So, I got a question about my s14 w/ a sr20det.. I recently put on new suspension and decided to take her out for a joyride... I get down the road and dumped the clutch and took off, after that I wanted to make sure she handled nice and slid nice... after the joy ride i brought her home and let her be.. I came back from little vacation an go to take her out. After I started her up she started to shake like crazy... not just the engine but the tranny also... doesn't sound like anythings knocking just shaking like crazy. broken vacum hose??? tranny mount??? I recently had a new clutch put in so I was thinking they could have over tightened a mount or something???? anyone got any ideas???
THANX
The408silvia is offline   Reply With Quote
Old 08-24-2010, 02:03 PM   #2
The408silvia
s14
nothing? anybody?
Old 08-24-2010, 02:08 PM   #3
T-FAST
T-FAST is an unknown quantity at this point
I would go back and check all the bolts that you messed with and re-torque them down. What suspension pieces did you put on?
T-FAST is offline   Reply With Quote
Old 08-24-2010, 02:11 PM   #4
Goodlucks7even
Goodlucks7even's Avatar
Goodlucks7even is an unknown quantity at this point
I had same issue w/ an s13, was simply the power steering oil that wasent enough thick
Goodlucks7even is offline   Reply With Quote
Old 08-24-2010, 03:09 PM   #5
s13pignose
s13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of light
Worth a shot but try checking see if your battery ground is tightened down on both ends at the post and at the motor? Also any difference with the clutch pressed in or out..good or bad?
s13pignose is offline   Reply With Quote
Old 08-29-2010, 07:46 PM   #6
slomar91
slomar91 is an unknown quantity at this point
sounds like your motor and tranny mounts are shot. Is it misfiring?
slomar91 is offline   Reply With Quote
Old 08-30-2010, 05:04 PM   #7
BoxerJackJohnson
BoxerJackJohnson's Avatar
BoxerJackJohnson is an unknown quantity at this point
Anymore details? is the car smoking does the car still rev normal?
BoxerJackJohnson is offline   Reply With Quote
