Old 08-02-2008, 03:54 PM   #1
Flicktitty
Flicktitty's Avatar
getting wheels widened
Has anyone on here ever had there wheels widened?
I like the wheels my coupe has but they are just too narrow and witht he new motor that it is getting there is no way will a 205 put ANY power to the ground. These wheels are from what i have gathered 15X7 Epsilon Mesh wheels TRUE 2/3 peice wheel. I plan on rolling and maybe pulling the rear fenders to run the 255 that i WANT to run on the back of the S13 Coupe.
So who should i get in contact with to get the wheels widened?
Thanks Zilvia!
Old 08-02-2008, 04:01 PM   #2
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
rb motoring might be able to help you out.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 08-02-2008, 07:40 PM   #3
thefro526
thefro526's Avatar
I've seen it done on steelies before but never a wheel like that. If it is a multiple piece wheel then you may be able to go to a custom wheel shop and see if they can make the rim piece wider.
thefro526 is offline   Reply With Quote
Old 08-02-2008, 07:47 PM   #4
slw240sx
slw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant futureslw240sx has a brilliant future
Send a message via AIM to slw240sx
give weldcraft in MI a call. weldcraftwheels.com
http://www.forcedfabllc.com/
slw240sx is offline   Reply With Quote
Old 08-02-2008, 08:12 PM   #5
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Better off buying a new set of wider wheels...Personally, I just dont trust a barrel to be cut in half and widened, too many shit that could go wrong. If you can find a wider barrel and just swap it, that would be alot better...
CLICK HERE!!!
Old 08-03-2008, 12:20 AM   #6
Flicktitty
Flicktitty's Avatar
Thanks i'll have to contact them on monday.
I have seen alot of VW guys run widened steelies and i FIGURED it would be easy to just take out the barrel and put in a wider one.
Thanks, i'll have to call them.
I threw that idea around a little, but idk if i want to find another set of wheels, i really like the ones on them and i don't have the funds for CCW Classic's right now.
Old 08-03-2008, 12:40 AM   #7
fliprayzin240sx
^^^You do know something like this wont exactly be cheap right? For the amount your gonna spend shipping it and having it modded, you could just buy another set of wheels. Thats the reason why its usually better to get another set of wheels thats already wide.
CLICK HERE!!!
Old 08-03-2008, 12:53 AM   #8
Flicktitty
Flicktitty's Avatar
yeah i know. to get the rears widened i'm geussing it's gonna be around 600-900ish. Which is alot of money. but to get wheels i like with tires i'm looking at atleast 2000. but who knows that might be a smarter bet
Old 08-03-2008, 02:28 AM   #9
efrain240sx
efrain240sx's Avatar
efrain240sx will become famous soon enoughefrain240sx will become famous soon enoughefrain240sx will become famous soon enoughefrain240sx will become famous soon enough
I talked to rb motoring about this when I bought my wheels off them, they told me it would be about $300 a wheel to turn my 8's into 10's. By the way my wheels are 3pc wheels. That should give you a idea on how much it's going to cost.
efrain240sx is offline   Reply With Quote
Old 08-03-2008, 03:46 AM   #10
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
Kodiak wheels sells custom barrels built to your spec.
I don't know why but a lot of companies sell multipiece wheels but weld them when they are all bolted up. If you are serious about doing this, peel off a small section of the silicone on your wheels and take a look to see if it's welded. I know wheels like SSR Agle Minervas are welded. I think SSR welds their Professors as well nowadays. I think Work might weld their VS series wheels but I'm not 100% sure. I know for a fact that Work Equips and Veilside Andrew V are not welded and can be completely disassembled.
For wheels like yours, it's just not worth it in my opinion. I would only do it to old school panasports or SSR's. You can go buy yourself better wheels for the price it will cost to widen yours.
EDIT: I just realized that the faces on the old school wheels like yours just pop off when you unbolt them. Even if the barrels are welded, you can stll bolt your faces on to some custom barrels. But then we're back to square one where your better off finding yourself some better sized wheels.
Flybert is offline   Reply With Quote
Old 08-03-2008, 12:19 PM   #11
Flicktitty
Flicktitty's Avatar
Thanks Alot guys for all the thoughts and suggestions. I really like the mesh look and these wheels seem really hard to find so i would like to run them. But i'm gonna make some calls monday morning to see what kind of prices it will be to widen them. And if it sounds like to much i might just get some wider rear wheels when i wanna run a sticky tire.
Old 08-03-2008, 01:24 PM   #12
TheWolf
TheWolf's Avatar
finding 15" tires that wide is more of an issue...
Eye on the Prize
Old 08-03-2008, 02:11 PM   #13
atutt
atutt's Avatar
atutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond repute
^I found an old Porsche with 345/35/15's lol..
atutt is offline   Reply With Quote
Old 08-03-2008, 05:46 PM   #14
Flicktitty
Flicktitty's Avatar
Drag radials
*duck*
Old 08-03-2008, 05:49 PM   #15
Matej
Flip the face inside out. It won't help you any, but they'll look deep.
Old 08-03-2008, 09:25 PM   #16
Flicktitty
Flicktitty's Avatar
/\ LOL thats awesome
Old 08-03-2008, 09:28 PM   #17
implayaz9
implayaz9's Avatar
implayaz9 is a well-known jackass
when u widen a wheel does the wheel just widen the lip of the wheel or no?..
implayaz9 is offline   Reply With Quote
Old 08-03-2008, 09:30 PM   #18
.jrmyrmx
.jrmyrmx's Avatar
.jrmyrmx is just really nice.jrmyrmx is just really nice.jrmyrmx is just really nice.jrmyrmx is just really nice.jrmyrmx is just really nice.jrmyrmx is just really nice.jrmyrmx is just really nice.jrmyrmx is just really nice.jrmyrmx is just really nice
i wonder if that would work with my watanabes
.jrmyrmx is offline   Reply With Quote
Old 08-03-2008, 09:35 PM   #19
Flicktitty
Flicktitty's Avatar
i THINK you can have them widen either ones. but i'm the one asking the questions so i don't really know.
Old 08-03-2008, 10:42 PM   #20
eek
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
You would have to find someone who can order you the barrels for those rims. Prob easier getting bigger/wider rims.
eek is offline   Reply With Quote
Old 08-04-2008, 05:58 AM   #21
TheWolf
TheWolf's Avatar
countach and panteras ran sizes like that... I think pirrelli makes a batch like once every 3 or 4 months.. they're like 400 a tire or so.. drag slicks and hoosier dot autox slicks not counting..
Eye on the Prize
