Old 02-23-2010, 04:24 PM   #1
jarend
jarend's Avatar
jarend is an unknown quantity at this point
5th gear went out - sr20det
So yesterday I was driving and went to put it in fifth gear and it made a gnarly grinding sound then stopped working. I was able to not touch the clutch and go from neutral to fifth. At first when I would push in the clutch and put it in fifth the rpm's would jump around a little like it was trying to do somethin then it would go to idle. Anyone had any similar problems? Suggestions? Anything would be greatly appreciated. Thanks. -Jaren
jarend is offline   Reply With Quote
Old 02-23-2010, 04:56 PM   #2
roninwon
roninwon's Avatar
roninwon is an unknown quantity at this point
Send a message via MSN to roninwon Send a message via Yahoo to roninwon
time for a new tranny
roninwon is offline   Reply With Quote
Old 02-26-2010, 02:38 PM   #3
jarend
jarend's Avatar
Yea, it seems like its just not worth fixing mine considering how cheap they go on here.. no one has had this happen to them before though?
Old 03-01-2010, 12:02 AM   #4
cutsprings
cutsprings is an unknown quantity at this point
Hi there I know im new to this forum but Im going to say... fix the trans yourself. Its actually pretty easy, you probably just tore 5th gear synchro a new one. LOL
Does it go into 5th gear while the car is off? if so then you just need a synchro. I have repaired 1 nissan trans and 1 toyota trans in the last month and they both ended up great! Only spent around 40 bucks to fix each one.
Any who good luck
cutsprings is offline   Reply With Quote
