Old 05-10-2016, 08:05 AM   #1
Joshhankins5
Joshhankins5 is an unknown quantity at this point
E85 rb25det?
I want to run E85 and have some questions as I haven't done it before.
Here are the mods I have so far:
DW200 Fuel pump
Stock injectors
Stock fuel rail
Fully built bottom end
Fully built top end
MLS Head gasket
ARP head bolts
Bored to 86.5mm block
stock turbo
I'm going to be running stock turbo setup till I have enough for the big turbo and manifold setup I want. Of course Ill be going Large injectors for that setup a couple months down the road. I'm just wondering If I can run e85 with stock turbo and stock fuel system till then? I'm doubting it since the stock injectors are 370cc I believe? Should I just run pump till big turbo? Will my DW200 be able to handle 600+ HP or will I need a dual pump setup?
Good injectors for running e85 with a Precision 6466 1.0 AR ?
Thanks
Joshhankins5 is offline   Reply With Quote
Old 05-10-2016, 09:31 AM   #2
jedi03
need bigger injectors definitely...
Old 05-10-2016, 09:56 AM   #3
Joshhankins5
I was assuming that but wasn't 100 Percent sure.
Old 05-11-2016, 07:01 AM   #4
Croustibat
Croustibat is an unknown quantity at this point
Bigger injectors and bigger fuel pump will be needed IF you run it at WOT.
You need to remap for e85, wether you use new injectors or not. Fueling and timing is different. If you cannot do it yourself, there is not much point doing it now.
What you could do for now is use a little ethanol mix to clean your fuel system before switching to bigger injectors and new pump. The car may run a bit lean so no WOT either ... 20 - 30% mix is ok.
Croustibat is offline   Reply With Quote
Old 05-11-2016, 04:28 PM   #5
Sforteen
Sforteen is an unknown quantity at this point
No you cannot use E85 on stock fuel system or injectors.. No real reason too until you get bigger turbo on it anyway.
DW200 is not enough pump for 600whp on E85 i would invest in the E85 version of the Walbro 450 Dubbed "485" should only need 1.
I wouldnt go any smaller than 1000cc injectors for your power goal
Sforteen is offline   Reply With Quote
Old 05-19-2016, 10:50 AM   #6
KAT-PWR
KAT-PWR's Avatar
Bosch 044
1600CC injectors
Retune
MRP Manufacturing
Old 05-19-2016, 11:32 AM   #7
RB25GUY
RB25GUY's Avatar
Originally Posted by KAT-PWR View Post
Bosch 044
1600CC injectors
Retune
seems about right if you can get the flex fuel reader would be in your best interest so you know what % of e85 you are getting
e85, rb25, rb25det
