Old 03-03-2014, 10:41 PM   #1
jamg
jamg is an unknown quantity at this point
Fresh SR swap, no power to ECU and fuel pump fuse, won't start
I'm done with the swap, ready for the first start, and i'm not getting any power to those fuses. my fuel pump doesn't prime, and the multi meter says im not getting any power to those fuses.
The upper/lower harness were attached and grounded before the motor was being dropped in. all of it is attached.
the green and black fuses that directly touch the battery is also hooked up and attached.
in the fuse box by the passenger side, the multi meter says all the fuses in there are getting power, except for the ECU and fuel pump.
i've already doubled checked the harness before the engine was dropped in, it's all hooked up.
the harness i am using is a wiring specialties harness.
I'm lost as to what to do. any advice?
jamg is offline   Reply With Quote
Old 03-04-2014, 12:34 AM   #2
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
is there any relays that might be shot?
Can you try jumping the fuel pump manually to verify it will prime.
Z32 with lq4 swap
Desert Street Scene || Dssevents.com
ultimateirving is offline   Reply With Quote
Old 03-04-2014, 12:42 AM   #3
bmxer882x
bmxer882x is an unknown quantity at this point
To do this just stick a single wire in the 2 closest plugs on the relay. I believe the fuel pump is on the egi relay. In my 90, it was the middle green one.
bmxer882x is offline   Reply With Quote
Old 03-04-2014, 12:49 AM   #4
jamg
a wire directly from the battery?
Old 03-04-2014, 01:00 AM   #5
bmxer882x
No, the plugs look like this
........_
-......._
Stick a 2 inch piece of wire between the two on the left. The closest 2
Old 03-04-2014, 05:23 AM   #6
Driftwire
Driftwire's Avatar
Driftwire is an unknown quantity at this point
+1 for relay issue.
Did you check the potato fuse located in the front right corner of your gas tank?
Originally Posted by RB33 View Post
No i haven't. To be honest i didnt know there was a fuse there. Thats not a fuse for the fuel pump is it?
Driftwire is offline   Reply With Quote
Old 03-04-2014, 06:15 AM   #7
jamg
I'll try that out. The car sat for a year, I'm pretty sure its all good..
Old 03-04-2014, 06:18 AM   #8
bmxer882x
also this shouldn't be the issue but you said the engine was grounded via harness, thats not near thick enough. I have 2 engine grounds directly from head to chassis and from intake mani to chassis, both being about 2 gauge in size.
Old 03-04-2014, 07:35 AM   #9
sleepyS14se
sleepyS14se's Avatar
sleepyS14se is an unknown quantity at this point
is the wiring specialties a brand new harness or is it a second hand harness?
95 S14 se RB25DET 348whp
sleepyS14se is offline   Reply With Quote
Old 03-04-2014, 10:57 AM   #10
jamg
i'll check for those. and if i dont have it, i'll make some.
bought it used. none of it was cut up or anything though..
Old 03-04-2014, 08:30 PM   #11
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
I say message Yuri at Wiring Specialties, he should be able to give you ideas on what to check. Also, what kind of SR and into what chassis?
CLICK HERE!!!
Old 03-04-2014, 09:45 PM   #12
jamg
s13 SR into S13
Old 03-05-2014, 01:04 PM   #13
Flyin_bryan
Flyin_bryan's Avatar
Flyin_bryan is an unknown quantity at this point
check to see if the ignition wire is hot to the f4 plug. black with a red tracer. if its not hot when the ignition is triggered then thats probably the culpret.
Flyin_bryan is offline   Reply With Quote
Old 03-05-2014, 01:27 PM   #14
jamg
will do.
thanks
Old 03-12-2014, 06:17 PM   #15
rebornS14
rebornS14's Avatar
rebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of light
Send a message via AIM to rebornS14
was the S13 a auto before you did the swap?
rebornS14 is offline   Reply With Quote
Old 03-13-2014, 07:51 PM   #16
kpnasty
kpnasty's Avatar
kpnasty is an unknown quantity at this point
im having this exact problem.. no ecu power, no prime, and no crank.. j4 ecu and new j4 wiring specialties harness. also jumped the EGI relay and it powered my pump. im as confused as you.
kpnasty is offline   Reply With Quote
Old 03-17-2014, 08:22 AM   #17
wiring specialties
wiring specialties's Avatar
wiring specialties is an unknown quantity at this point
Please give us a call and we will be more than happy to help you sort out the issue if you still haven't.
-Brandon
wiring specialties is offline   Reply With Quote
Old 03-17-2014, 08:39 PM   #18
wiring specialties
Most of the time when the ECU seems dead with key on, the ECCS circuit is faulty.
Once the ECU sees ignition key on (black/red wire to 12V), it will send a ground signal from pin 4 to the ECCS relay, which will then power the sensors, including the ECU.
If that signal is not generated by the ECU, the whole system will look completely dead.
As suggested above, first step is to see if the ignition wire gets 12V. Its at the GREY 8-pin plug by the pass headlight. Check the RED wire for constant 12V. If both check out, i would say the ECCS is next. The small red/black wire in the brown connector by the headlight is the control wire. If it sees ground, i am sure all will come alive.
Any questions, just hit us up...
