Old 02-02-2012, 08:16 PM   #1
rahjah
rahjah is an unknown quantity at this point
Dropping cylinder 2
I am losing number two cylinder in my 92 240 with the ka24de. I have spark and isn't all the time. I was thinking the number one and number two injectors and seeing if the problem moves. Would this be the next best thing to do? Also, I just replaced the cap and rotor and the car ran great to the gas station and ran on three cylinders on the way back.
rahjah is offline   Reply With Quote
Old 02-02-2012, 08:23 PM   #2
rahjah
I was thinking of replacing the fuel filter but the problem seems lie in the number 2 cylinder only. When it is running poorly, I can pull cylinders 1, 3 and 4 plug wires and the engine bogs way down. However, when I pull the number 2 plug wire, nothing changes.
Old 02-02-2012, 08:36 PM   #3
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
how does the spark plug on cyl 2 looks like compared to the other 3 cylinders?
rcdad123 is offline   Reply With Quote
Old 02-02-2012, 08:39 PM   #4
rahjah
I only looked at the numbers 1 and 2 plugs for a comparison and the both look the same, and smell the same.
Old 02-03-2012, 02:06 PM   #5
rahjah
I think that I may have narrowed it down to a bad ignition control module.
Old 02-03-2012, 04:28 PM   #6
Walperstyle
Walperstyle's Avatar
try swapping injectors first with a different cylinder see if the problem follows the injector to a different cylinder.
KA-T ORG-Function over Flush
Old 02-03-2012, 04:31 PM   #7
rahjah
I tried swapping the injectors today but I was unable to get them out. I almost broke the top off of the number 1 injector trying to pull,pry it out. Is there a safe/easy way to do this. Also, I took the ICM to work (Advance Auto Parts) and tested it, it failed twice in a row.
Old 02-04-2012, 05:09 PM   #8
rahjah
Swapped injectors 1 and 2 today, the problem followed the number 2 injector. Replaced injector, all is well.
Old 02-04-2012, 05:27 PM   #9
Walperstyle
Right on buddy!
