For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
Nissan R200 Final Drive Ring & Pinion Gear Set 3.538 (46:13) Ratio
Nissan Infiniti 240SX 180SX SILVIA SKYLINE 300ZX Q45 R200 Final Drive Ring & Pinion Gear Set 3.538 (46:13) Ratio.
If upgrading from a stock 4.083 ring gear from a 240sx this gear set will give you a higher top speed. Ideal for cars putting down more power that would like to cruise on the highway at lower RPM. This is the ultimate top speed final gear ratio for R200! Comes with LH and RH shims and M13 ring gear bolts. ![]() ![]() ![]() $320 shipped. PM me for quickest response.
![]() Last edited by KiLLeR2001; 02-08-2016 at 06:56 PM.. |
![]() Join Date: Jun 2008
I understand how a final drive gear works. But I don't understand how this makes your car able to cruise at lower RPMs. I thought the ring gear is only to transfer power from input propellor shaft. So you hit a wall with the stock gearing when you have a high horsepower car. due to the Differential. So to get power in high boost situation on WOT you have to get a ring drive that transfers all the power to the output shafts at the increased capability of the turbo engine? So you need to have this gearing or you'll be slower due to the slipping of the stock differential gearning , ie 4.083
Im immune to bullshit....so put your shovel away. |
