Old 09-30-2012, 07:50 PM   #1
JonathanPrem
JonathanPrem's Avatar
JonathanPrem is an unknown quantity at this point
Question S13 FLCA On s14 zenki
Currently running around -6 to -8 camber in the front(had to put spacer for brakes so don't flame me). Was wondering If i run s13 flca will i be able to run around -4 to -5 camber?
I'm currently running 20mm wide fender and my wheels specs are 18x9.5 -26(including 20mm spacer) with 215/40(will be running 215/35 next summer).
All i need to mount s13 flca is s14 bj and use the same bolts right? Will the bushing be the same?
JonathanPrem is offline   Reply With Quote
Old 09-30-2012, 08:29 PM   #2
karl wasabi
karl wasabi's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
Do you have coilovers? You should just take out camber with the top plates. You CAN put S13 FLCA on but you'll have to change the ball joints on the S13 LCA since S14 is larger. It can be done, but probably not worth it.
Old 10-01-2012, 07:16 AM   #3
JonathanPrem
Problem is i cant take out the camber. If i do my wheels well rub. I bought the wheels with out thinking about bbk.
Old 10-01-2012, 08:31 AM   #4
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
S13's have a narrower track width than S14's so keep that inmind if/when you do it. My vote, buy wheels that fit or go to a smaller brake setup. You obviously don't need a BBK setup rolling around on those ridiculous offsets.
My SR20VET
