Old 07-17-2012, 11:33 PM   #1
hmongs13
hmongs13's Avatar
hmongs13 is an unknown quantity at this point
rb20 transmission noise?
after swapping the rb20 into my s13 i notice that when i press the clutch pedal all the way, its making some whining noise. when i took the tranny off from the motor the clutch was good, the throw out bearing was in great shape and the fork was good too. i also changed the fluid(75w90), put about 2.2-2.5qrt. i search but i couldn't get a clear answer, some say that the throw out bearing only make noise when not pressing the clutch. so any helps zilvia members?
hmongs13 is offline   Reply With Quote
Old 07-19-2012, 06:33 PM   #2
hmongs13
hmongs13's Avatar
any help guys?
Old 07-19-2012, 06:51 PM   #3
Jtuned_andy
Jtuned_andy's Avatar
Jtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud of
could be an internal bearing groaning or your may be paranoid, either way hard to tell. replacements are cheap enough
http://home.comcast.net/~skunk.werkz/r32_sig.jpg
Jtuned_andy is offline   Reply With Quote
Old 07-19-2012, 10:01 PM   #4
hmongs13
hmongs13's Avatar
oh. i guess ill just live with it..
Old 07-20-2012, 02:16 AM   #5
zerodameaon
zerodameaon's Avatar
Could have broken the tube that the TOB slides on, did you check that?
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
Old 07-20-2012, 10:00 AM   #6
hmongs13
hmongs13's Avatar
i dont think it could be that, if its broken shouldnt the tob and fork wouldnt work?
Old 07-20-2012, 01:22 PM   #7
zerodameaon
It can still work, you will just get a grinding noise when you put in the clutch, unless its really tweaked then you will loose your clutch all together.
Old 07-20-2012, 10:49 PM   #8
hmongs13
hmongs13's Avatar
oh and i also notice it was kind of hard to get into 4th and 5th gear, 1st-3rd gear went smooth but when shifting to 4th and 5th you hear a clunk noise so you have to force it in...
Old 07-21-2012, 02:01 AM   #9
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
Send a message via AIM to hOngsterr
hmong... and from norcal...
thats so funny, so have you seen the hmong jedi?
jk but yea.
sounds like your syncros might be fucked, also i was going to say it might be your driveshaft, but from reading more, im not sure then.
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
hOngsterr is offline   Reply With Quote
Old 07-21-2012, 02:49 AM   #10
hmongs13
hmongs13's Avatar
yes hmong jedi in youtube...lol..will hummm i dont know either...i might as well just go back to the shop and exchange for another one!
