Old 01-16-2019, 10:52 AM   #1
amreboot
amreboot is an unknown quantity at this point
SR20 ECU Question
Hey all
Quick question...
I have searched and was unable to yield any straight answer, but will the SR20 ECU from a Sentra work on the S13? The ECU would have Nistune and be turbo tuned.
Just curious if this is a thing.
amreboot is offline   Reply With Quote
Old 01-16-2019, 11:43 PM   #2
DennisC
DennisC's Avatar
DennisC is an unknown quantity at this point
Most likely not
DennisC is offline   Reply With Quote
Old 01-17-2019, 07:51 AM   #3
TheRealSy90
TheRealSy90's Avatar
Actually, early s13 sr20 ecu plugs is the same as the early sr20 sentra. I have had a friend start his sr20det sentra off of my redtop ecu before. Not sure if he had to change any settings or pinout though, etc.
Such a good signature.
Old 01-17-2019, 07:57 AM   #4
LoSt180
LoSt180's Avatar
Trader Rating: (18)
LoSt180 is an unknown quantity at this point
Feedback Score: 18 reviews
No, mainly because the Sentra is a DE motor with a distributor for ignition and the DET motor is direct (coil-on-plug) ignition driven from the ECU. Could probably make it work, but you'd have to sort out some kind of external ignition module.
The connector is probably the same, just the pins wouldn't match up.
LoSt180 is offline   Reply With Quote
Old 01-29-2019, 01:37 PM   #5
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
this is the big concern here is single coil and coil on plug and sorting that out
but as for the pins. they should all be in the same spots between the 2 ecus (atleast the important ones)
The Game
you lose haha
kyral is offline   Reply With Quote
