Old 03-01-2012, 08:36 PM   #1
gue399108
gue399108 is an unknown quantity at this point
What type of oil to use
I just bought my 93 240sx and im going to do an oil change for the first time. Any suggestions on oil to use and what weight?
gue399108 is offline   Reply With Quote
Old 03-01-2012, 08:39 PM   #2
Edwin562
Edwin562's Avatar
Trader Rating: (35)
Feedback Score: 35 reviews
Just cuz im feeling nice...this could help you out.
How to choose the right motor oil for your car
Old 03-01-2012, 09:11 PM   #3
adrians_s13
adrians_s13's Avatar
shoulda asked like a couple days ago cuz Pep Boys was having a sale on 5 qts of Royal Purple.
<3 RP
@adrianfromthecastle
adrians_s13 is offline   Reply With Quote
Old 03-02-2012, 06:54 AM   #4
Croustibat
Croustibat is an unknown quantity at this point
ready to open can of worm ?
Croustibat is offline   Reply With Quote
Old 03-02-2012, 06:57 AM   #5
240sxKouki
240sxKouki's Avatar
240sxKouki is an unknown quantity at this point
Thats what I was thinking.
240sxKouki is offline   Reply With Quote
Old 03-02-2012, 07:13 AM   #6
Croustibat
that article is full of various technical words but does not help in any way.
There is only 1 way to go :
0/make sure your oil pump is ok ...
1/find manufacturers recommended pressure range, in the workshop manual most of the time.
2/try different oil viscosities until you match them.
If pressure when cold is too high, it means your cold viscosity is too high (too thick)
If pressure when hot at idle is too low (considering manufacturer spec, not your own feeling), your oil pump is most likely shot, or you are using a way too thin oil.
Min and max pressure range at around 3000rpm when hot will give you the correct hot viscosity number. "Hot" is the temp where the car is used, usually 90-100° for a street car, 100-120° for a tracked car.
If your temp is colder (unless it is a drag car run quite cold) or hotter, you have a problem with your engine, fix that first.
this works for EVERY 4 stroke engine.
Old 03-02-2012, 07:16 AM   #7
s13silvia123
s13silvia123's Avatar
use this it is the best out there Redline MT-90
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
Old 03-02-2012, 09:18 AM   #8
0wn3r
0wn3r's Avatar
0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of
WTF? That's transmission fluid.
To OP:
Figure out what motor you have.
Find the factory service manual for it and read the fluids and lubricants section that will tell you how much and what weight.
Don't listen to hype about how super cool and expensive my oil is. Just search and read and make your own judgements...you can't honestly think that a thread (or 1,000) like this hasn't been made yet right?
If it's stock KA and you're not doing anything special or have any oil issues, use regular oil-- You don't need anything fancy.
Close thread.
97 240sx se
0wn3r is offline   Reply With Quote
Old 03-04-2012, 04:29 PM   #9
soryu
soryu's Avatar
soryu is an unknown quantity at this point
5w30 all day.
soryu is offline   Reply With Quote
Old 03-04-2012, 07:13 PM   #10
mr.man.performance
mr.man.performance's Avatar
mr.man.performance is an unknown quantity at this point
I have a bone stock ka24de...probably what you have. 5w30. If you're somehow running an sr20det, between 5w30 to 10w40 depending on how much you're boosting and the climate of your area. Royal purple is sweet but expensive. I usually just roll with either castrol gtx full synthetic or mobile 1 synthetic. Just me though..
mr.man.performance is offline   Reply With Quote
Old 03-19-2012, 09:01 PM   #11
TheRealSy90
TheRealSy90's Avatar
Mobil1 15w-50 if you are in a warm climate.
Such a good signature.
