Old 09-09-2009, 10:02 PM   #1
ixfxi
ixfxi's Avatar
Interior question about seatbelt delete panels
I've been here for ages, never really seen anyone discuss this before but I know that the answer is out there.. so I will ask.
For us US 240 owners, is there a 100% clean solution to eliminating the US interior panels and putting replacement panels that DO NOT HAVE PROVISIONS for the auto seatbelts?
Now, I know we're going to start talking about J-spec and Canadian-spec parts. But which ones?
A-PILLAR COVERS
The J-spec A-pillar covers SHOULD have a provision for the "oh shit" handle which normally comes on the LH side of the car (for Japan). So, we cannot use the J-spec panels. Furthermore, I already have the "oh shit" handle and have installed it on the RH (passenger) side of my car. Correct me if I am wrong, but I believe the answer is to attain the Canadian a-pillar covers. Can anyone confirm?
B-PILLAR COVER
I'm going to take a guess and say that the J-spec OR Canadian b-pillar covers should work. Also, I am going to assume that the B-pillar covers used in Japan and Canada have provisions for the manual seatbelts? Can anyone confirm?
Headliner
I've read that there are differences between the various different headliners for our cars. What are the differences between US-spec, J-spec, Canada, etc....? Please share info.
Please post any information and/or pics, because I would like to actually complete my car sometime this lifetime and possibly even attend the 240sx convention in 2030.
Thanks,
Mike
Old 09-09-2009, 10:06 PM   #2
BoostedCoupe
BoostedCoupe's Avatar
BoostedCoupe can only hope to improve
I fail,
dfsvsdfvsd
92 vert converted 5speed and other little things
BoostedCoupe is offline   Reply With Quote
Old 09-09-2009, 10:12 PM   #3
ixfxi
ixfxi's Avatar
Originally Posted by BoostedCoupe View Post
How big of a diffrerence is the s14's from the s13's? last ime i took a coupe apart they looked some what similar.
please leave.
seriously.
you're fired.
Old 09-09-2009, 10:19 PM   #4
Taniguchi_Is_#1
Taniguchi_Is_#1 is close to perfectionTaniguchi_Is_#1 is close to perfectionTaniguchi_Is_#1 is close to perfectionTaniguchi_Is_#1 is close to perfectionTaniguchi_Is_#1 is close to perfectionTaniguchi_Is_#1 is close to perfectionTaniguchi_Is_#1 is close to perfectionTaniguchi_Is_#1 is close to perfectionTaniguchi_Is_#1 is close to perfectionTaniguchi_Is_#1 is close to perfectionTaniguchi_Is_#1 is close to perfection
a-pillars: yes, canada
b-pillars: jdm and canadian, both have manual belts. i think european models have manual belts also.
edit for b-pillars: there are no panels that have zero seat belt provision. the cars in other markets have a hole cut out for the seatbelt.
all headliners for all markets are the same, unless there were some special materials used in certain markets, but the shape is the same.
Taniguchi_Is_#1 is offline   Reply With Quote
Old 09-09-2009, 10:23 PM   #5
ixfxi
ixfxi's Avatar
does anyone happen to have an extra 180sx a-pillar cover, or a photo that they can share?
I'de like to either make a template, or at least SEE exactly how the a-pillar cover was cut for the "oh shit" handle, that way I can make a proper cut to the canadian a-pillar cover
thanks for the info, and if you guys have any pics that you can contribute with, feel free to share. besides broadfield, i dont think there are too many other guys here who actually care about CLEAN INTERIOR... (or even owning a clean 240)
Old 09-09-2009, 10:24 PM   #6
S14_Kouki
S14_Kouki's Avatar
Ill for sure have my s14 in 2030 but will I be the only one at the convention besides you ahahahahahah gl with your search i dont have interior lol
S14_Kouki is offline   Reply With Quote
Old 09-09-2009, 10:42 PM   #7
^fraktal^
^fraktal^'s Avatar
^fraktal^ will become famous soon enough^fraktal^ will become famous soon enough^fraktal^ will become famous soon enough^fraktal^ will become famous soon enough^fraktal^ will become famous soon enough
i don't have any experience with cdm parts so i'll only compare jdm vs. udsm
jdm a-pillars panels are not as wide. they clip directly into the frame and have no gap for the auto belts obviously.
usdm a-pillars are wider and more flared due to the auto belt track. these also clip into little metal brackets that are bolted to the frame...pretty redundant honestly if you've already stripped the auto belts.
the jdm headliner is also wider because the a-pillar panels are not as wide. if you use jdm a-pillars and a usdm headliner there will be like a 1" gap between the liner and panels, just on the section above the windows.
the jdm b-pillars have the cutout for manual belts already. however there is a small trim piece that clips into this cutout and is usually only found on the jdm seatbelt assemblies themselves. that's in my experience anyways. you can use the usdm rear seat side panels still with the jdm b-pillars and have no worries.
i'm using jdm a and b-pillar panels in my car with a usdm headliner. i can take pics for you but won't be able to have them up until tomorrow.
^fraktal^ is offline   Reply With Quote
Old 09-09-2009, 10:46 PM   #8
lflkajfj12123
jspec used to have the whole set for manual belts on the site
maybe he has a picture still?
Old 09-09-2009, 10:56 PM   #9
ixfxi
ixfxi's Avatar
thanks for the more factual info, i **KNEW** there was a fucking difference with that gaddamn headliner.
My car is not fitted with seatbelts, it uses schroth harnesses w/ rollbar. The auto seatbelts were eliminated like 10 years ago, that shits history.. and I dont plan on installing manual seatbelts either, I had S14 belts for a while and dumped them in exchange for the harnesses.
this is why i am seeking a setup that has the least amount of holes or provisions. now the question is, how big is the hole/provision for the manual seatbelt in the b-pillar cover?
if you want, you can email the pics to me at [email protected] if you dont want to deal with hosting. i'll can host them for you.
thanks guys
Old 09-10-2009, 12:04 AM   #10
jon_mr2
jon_mr2 has a reputation beyond reputejon_mr2 has a reputation beyond reputejon_mr2 has a reputation beyond reputejon_mr2 has a reputation beyond reputejon_mr2 has a reputation beyond reputejon_mr2 has a reputation beyond reputejon_mr2 has a reputation beyond reputejon_mr2 has a reputation beyond reputejon_mr2 has a reputation beyond reputejon_mr2 has a reputation beyond reputejon_mr2 has a reputation beyond repute
yeah, so i didnt know the headliners were different till i tried to install the panels for the j-spec manual seatbelts. i did however make these things out of cardboard to fill in the gap between the headliner and panels... yeah, i know it sounds kinda cheap, but i just wanted to get it done. but it didnt turn out too bad in my opinion.
sanded the extra fabric down a little to give it a smoother look
two layers of headliner later, it looks good. just a slight line of uneveness where the extra peices were added on, but i dont think anyone would notice unless i told them. could have spent a little more time on it to make it better... maybe next time. and it turned out very plush like.
here it is installed... kinda
as for the seatbelt holes in the panels, there is just an opening where the belt pulls between the b-pillar panel and that lower rear side panel.
hope that helps some.
jon_mr2 is offline   Reply With Quote
Old 09-10-2009, 02:43 PM   #11
Taniguchi_Is_#1
i never knew that. that's interesting.
Old 09-10-2009, 06:12 PM   #12
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
LOL where have you been? If you wanted JDM belts and the A and B pillar it was a very commented upon fact. LOL
Anyways Mike you got your answers.
New Video
Buy my mounts!
http://zilvia.net/f/sale-items/51531...ns-mounts.html
http://zilvia.net/f/tech-talk/317539...e-mouts-6.html
Old 09-10-2009, 06:39 PM   #13
Devil Man
Devil Man is an unknown quantity at this point
just as jon mr2 posted your car will look like that if you use either the jspec or canadian spec a pillar. please make note that not all of these came with the "oh shit" grip as mine dont have them and i have seen other that dont aswell. the b pillar is also the same jspec and canadian spec.
you will have to modify your head liner like jon mr2 did or come up with a way to make up for the gap. unless you can get a jspec or canadian one... but that wouldnt be cost effective.
also once this has been done. since you remove the lap belt you will be left with those retarded humps that are molded into the carpet in the rear floor bords and on the rocker panels too. i am 99% sure that a s14 carpet will fit our s13's and effectivly delete that stupid looking humps and clean up the apperiance of the car too. this is where i am at now trying to find a clean s14 carpet to experiment with this theroy of mine.
not to be a dick, but to be a dick....
Devil Man is offline   Reply With Quote
Old 09-10-2009, 06:50 PM   #14
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
sonavagun ive been looking for these pics and info forever...fucking thank you
Mike
im currently working on getting JDM seatbelts but going to get a canadian left a pillar panel, then, with what jon_mr2 just posted im gonna retrofit the headliner...keep an eye open here http://zilvia.net/f/tech-talk/274827...y-pillars.html
if u like
from my understanding u can use a Q45 Oh shit handle if ur pillars don't come with it...
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 09-10-2009, 07:34 PM   #15
Taniguchi_Is_#1
ah. haha. yeah, i've never cared that much about manual belts, so yeah. haha.
Old 09-10-2009, 08:32 PM   #16
^fraktal^
^fraktal^'s Avatar
so yeah finally got a couple pics. pretty much been answered already but just fun to see i guess. jon i really like what you did to your headliner, good job! yes i know my sun visors are brown, so was the whole interior originally i'm just slowly getting it all swapped over to black.
here you can see the usdm headliner gap with the jdm panels:
here you can see how the jdm belt is run. the usdm rear seat lower panel will still work in this case since the belt runs behind the b-pillar and out through the top. also notice the secondary trim piece that is a part of the belt assembly.
oh shit handle with headliner gap. somebody should mold some plastic caps for those 2 spots...or start sourcing just the single canadian panel and headliners exclusively lol.
random shot just showing how the jdm panels have no auto belt gap crap. they just fit so much better without the stupid little metal brackets that the usdm panels require.
hmm that's interesting info. perhaps the panels without the oh shit handle were from older ca equipped zenki's? who knows? i have only seen jdm panels with the oh shit handle. there's really no easy way to install one of those handles on the passenger side of a us car anyways. the a-pillar is molded a special way and there's a seconday bracket that it bolts to. i tried just flipping over the bracket before and using it on the us passenger side but it doesn't work. you'd still have to cut holes in the a-pillar then too, but it won't sit as flush because it won't be molded the same.
i'm also interested if an s14 carpet will work like you theorize. i finally got my hands on a clean black s13 240sx carpet to put in, but hate those stupid belt assembly humps too!
Old 09-10-2009, 09:31 PM   #17
Devil Man
ok why is it that you dont have those computers in the space were you installed those speakers? and while i am at it what the hell are those computers for anyways they are on both sides in that hole??? i havent been able to figure it out.
and i figured the same thing that the A pillars that i have are from a base model that doesnt have the "oh shit" grips. it makes sense.
Old 09-10-2009, 09:44 PM   #18
^fraktal^
^fraktal^'s Avatar
ah, well i don't have them because my hatch is a base model
for your car the module on the driver's side is the abs control unit and the module on the passenger side is the hicas control unit.
Old 09-10-2009, 09:47 PM   #19
Devil Man
holy shit you are my fucking hero... i think i might just go out there right now and gut them sumba bish's out right now cause im 5lug which deleted my abs and i swaped my rear subframe for non-hicas subframe.. so yea they gots to go!!!!
Old 09-10-2009, 11:28 PM   #20
ixfxi
ixfxi's Avatar
chances are, my car will not have a factory-style headliner nor does it have any carpet, its stripped to a very light-weight N1-style configuration. So i am not worried about the above, the only items I care for are the a-pillar covers and various rear covers. thanks for the info though!
mike
Old 09-11-2009, 09:14 AM   #21
ranger240
ranger240's Avatar
ranger240 is a jewel in the roughranger240 is a jewel in the roughranger240 is a jewel in the roughranger240 is a jewel in the roughranger240 is a jewel in the roughranger240 is a jewel in the roughranger240 is a jewel in the roughranger240 is a jewel in the rough
would it be possible to order that Bpillar seatbelt hole trim piece from some dusty ass nissan warehouse from god knows where?
does any nissan wizard out there know the part #
people with USDM stuff could probably make do with just popping in that seatbelt hole plug thing. at least until they source jdm/cdm stuff
also as far as a pillar stuff is concerned.. you could probably fill in any holes and wrap that in a headliner-looking material, thats what all the benzes and bmws have.. it might look weird on our cars though. especially if youre not running a headliner.. maybe vinyl wrap?
Originally Posted by surreybc
...common sense is for uneducated people who operate on animal instinct.
ranger240 is offline   Reply With Quote
Old 10-23-2009, 02:10 PM   #22
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
sorry for reviving the dea..but, i have a contact in Canada that can get me the CDN A pillars...and im wondering...does anyone know the part numbers....canadian A pillar numbers...?
PSN
Old 10-27-2009, 11:12 AM   #23
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
i still need help with this gents...i need a VIN# to help me
i called a CDN dealership and they need a CDN Coupe Vin# to search for the right parts...(the A pillars)
PSN
Old 10-27-2009, 11:44 AM   #24
twistedsymphony
twistedsymphony's Avatar
twistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of light
Find a Canadian 240sx for-sale add, call the schmuck and tell him you want the VIN to run a CarFax
twistedsymphony is offline   Reply With Quote
Old 10-27-2009, 11:48 AM   #25
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
lol i wonder...
i rather get help from a willing party lol
i have a coworker heading up to point clair in Dec...and the dealership said it would take a month for the parts to arrive, so right now is the time to strike!!!
PSN
Old 11-16-2009, 11:43 AM   #26
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
bringing this back from the dead once more...
getting this as soon as they hop the border from Canada...YAY!
a littles dirt dont hurt no one...
PSN
Old 11-16-2009, 01:55 PM   #27
Devil Man
wait can you get parts for the panels? the stupid ring/trim or whatever you want to call it that goes around the seat belt on mine is cut through and i would like to order another one. as for parts numbers i cant help ya sinee my parts have no numbers on them! gl!
and my god the op is still temp-banned... thats really ashame he does have alot of usefull information and insite.
Old 11-16-2009, 02:21 PM   #28
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
i actually got the complete set up for trade straight from the source...and i couldnt be happier...right now just playin the waiting game for tracking number...once i get my stuff i send out his stuff...and the world keeps spinning...
BTW...A pillars are interchangable between coupes and hatches, JIC anyone didnt know
PSN
Old 04-29-2011, 02:04 PM   #29
Conrad 2NR
Conrad 2NR's Avatar
Conrad 2NR is an unknown quantity at this point
Is there a difference between the coupe and hatchback headliner? I have a motorised sunroof in my hatch but no headliner.
I searched and I'm not finding anything so I thought I'll post here.
Conrad 2NR is offline   Reply With Quote
