Old 07-26-2012, 01:22 AM   #1
grimm199
grimm199's Avatar
grimm199 is an unknown quantity at this point
Can't rev past 5.5k??
96' S14
Cant rev past 5.5k, and it acts like it's a rev limiter. Bad MAF or what??
Mods:
OBX Header, eBay exhaust, 248 Intake side cam swap.
CEL Codes:
14 Speed sensor
32 EGR
77 Rear O2, Because of header
108 EVAP volume control
http://www.youtube.com/watch?v=Nkpf7Cszk7c&feature=player_embedded
grimm199 is offline   Reply With Quote
Old 07-26-2012, 01:57 AM   #2
cotbu
cotbu's Avatar
5.5k rpm limit is usually speed sensor, since you have a code for that, start there.
Old 07-26-2012, 02:07 AM   #3
grimm199
grimm199's Avatar
It hasn't been plugged up. It just started to do this about a week or two ago.
Old 07-26-2012, 02:22 AM   #4
cotbu
cotbu's Avatar
It took a few cycles then, you wanna argue some more about why your car is acting stupid?
Try this, fix all the codes so the check engine light turns off!
Old 07-26-2012, 01:40 PM   #5
grimm199
grimm199's Avatar
So you think its the speed sensor? I'm not trying to argue I'm just wondering why that would be if it's not even Hooked up?
Old 07-26-2012, 01:45 PM   #6
cotbu
cotbu's Avatar
That's why, hook it up, if it's faulty replace it! If you cut the speed signal wire from the ecu, fix it. If it ain't broke don't fix!
Old 07-26-2012, 01:52 PM   #7
Karlitos
Karlitos's Avatar
Karlitos is an unknown quantity at this point
I went through this about a month ago. Cam timing was off by 1 tooth. Check that. Before that I had checked 5 speed sensor, MAF (tried 3 diff ones), tps (voltages checked out). I even changed the dizzy.
But ill bet its cam timing since you have the 248 cam swap.
'95 240sx | '01 Mazda Miata | '18 Tesla Model 3
Karlitos is offline   Reply With Quote
Old 07-26-2012, 02:01 PM   #8
grimm199
grimm199's Avatar
I was thinking it might have been the timing. I guess I'll be checking that soon then!
And I haven't had the time to get the right Speed sensor. Right now the only thing in there is an S13 one just to plug up the hole. I was hoping I could get one soon, but I'll be checking the timing soon though. Thanks!
Oh and do you think I need to set the 248 to 3teeth CCW since its messing up at 4 teeth? I've seen both the 3 teeth and 4 teeth but I don't know which one is better. I guess 3 teeth then. I new to redrill my old one.....
Old 07-26-2012, 05:29 PM   #9
cotbu
cotbu's Avatar
I'm still standing behind speed sensor, although I couldn't duplicate your problem moving the 248 cam either way, I must be doing it wrong lol. When I disconnected the speed sensor, I didn't have to wait for a couple starts for the limiter to show with a code. I also left the speed sensor connected during the first 2 adjustments of the cam. Then again this car was problem free before I F'd with it. Hope you get it fixed though, G/L
Old 07-27-2012, 02:21 PM   #10
Karlitos
Karlitos's Avatar
Sorry, I wouldn't know how many teeth to move the 248 cams. As I have stock cams, all I know is I tried everything and it turned out cams were off by 1 tooth after the rebuild.
Old 07-28-2012, 01:44 AM   #11
grimm199
grimm199's Avatar
So did you just use the light and turned the distributor to correct the timing?
Old 07-28-2012, 08:34 AM   #12
MADE
MADE's Avatar
MADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant future
Had this issue with my RB after checking everything it ended being the leaky BOV.
MADE is offline   Reply With Quote
Old 07-28-2012, 12:51 PM   #13
Karlitos
Karlitos's Avatar
No, cam timing was off by 1 tooth. Had to pop off valve cover and reposition the cams. I'm just saying I wouldn't know which way to turn the 248 cam to fix it.
Old 07-28-2012, 01:29 PM   #14
cotbu
cotbu's Avatar
If you don't wanna take my advice it's fine. I used a car with the same mods as you and tried to duplicate your problem. So if you really are trying to fix your issue just document what you have tried, are trying or will try... for future searches/ers. This thread should not be a six pager!
Old 07-29-2012, 09:02 PM   #15
grimm199
grimm199's Avatar
So it did it again today, but this was the worst it has done it. I was getting on the on ramp, dropped it to 2nd, and when I hit 5.5K,it bounced off once like it would have been the fuel cut off, so I shifted into 3rd. Absolutely no throttle response, RPMs slowly went down from 5k and wouldn't get any response until it got back down to around 500rpm then back to idle. Does it sound like timing still or more of a speed sensor? Sorry to keep bumping this, just figured I would post it since it
Old 07-30-2012, 08:03 AM   #16
shoguner
shoguner is an unknown quantity at this point
Just fix the damn speed sensor, then you won't have to question if its the sensor.
shoguner is offline   Reply With Quote
Old 07-30-2012, 12:17 PM   #17
Nismo11
Nismo11 is an unknown quantity at this point
^^ yea easy to replace.
Nismo11 is offline   Reply With Quote
Old 07-30-2012, 12:25 PM   #18
grimm199
grimm199's Avatar
It's called fucking money alright, and it's something I don't fucking have. I was asking so I could be sure to buy what I mainly only really need right now.
Old 07-30-2012, 12:32 PM   #19
Ramonesfreak2010
Ramonesfreak2010's Avatar
Ramonesfreak2010 is an unknown quantity at this point
Then you shouldn't own a 240sx.
Ramonesfreak2010 is offline   Reply With Quote
Old 07-30-2012, 12:35 PM   #20
grimm199
grimm199's Avatar
Typical response. Right now I just have more important things I need to keep my money for than to pay $50 for a little sensor. Will I buy one? Yea, just not very soon, but I will be buying one.
Old 07-30-2012, 02:43 PM   #21
rwtf
rwtf's Avatar
rwtf is an unknown quantity at this point
ecu, mine did the same thing. Heres my vid.
5k Rev limit?! WTF. - YouTube
rwtf is offline   Reply With Quote
Old 07-30-2012, 02:50 PM   #22
grimm199
grimm199's Avatar
^ I have an auto ECU at the house so I can try that when i get home.
Old 07-30-2012, 02:51 PM   #23
rwtf
rwtf's Avatar
yeah i swapped out mine for a auto and it worked fine.
Old 07-30-2012, 03:36 PM   #24
cotbu
cotbu's Avatar
Half Broken Things!
Old 07-30-2012, 08:42 PM   #25
grimm199
grimm199's Avatar
This is happening randomly. Today I was driving home, dropped it to 2nd, and went over 5.5k RPM just fine. So then after that, I just pushed in the clutch and revved all the way to 6k just fine. I'm picking up the other ECU now, but on the way to my dads house I will try and see if it does it any more. I'll swap out the ECU tonight and drive it some and test it out. We're trying to find the timing light, but can't find it right now so if it persists then ill definitally check timing, then get the right speed sensor of timing is right.
Old 07-30-2012, 10:36 PM   #26
grimm199
grimm199's Avatar
Ok guys. Looks like it is my ECU. Swapped the auto ECU in, drive up to 6k 1-4th fine, revved up all the way fine. Stopped, swapped the manual one back in, took off and it wouldnt go over 5.5k in 1st or 2nd. Stopped again, swapped auto ECU back in, drove, and it was perfect again. New ECU it is!
Old 07-31-2012, 01:04 AM   #27
cotbu
cotbu's Avatar
It's not the ecu, just in case you ever want to get to the bottom of your problem for future searchers, at least, try a manual ecu! When, If you ever upgrade ecu's or get a tune done you have to remember to tell yourself you have a manual with auto ecu. Or fix the problem.
Originally Posted by cotbu View Post
Half Broken Things!
Old 07-31-2012, 11:31 PM   #28
grimm199
grimm199's Avatar
Ok so another update guys. So it only does it when it's trying to accelerate. I was in 2nd, took off to 5500 and it bounced off, so I pushed in the clutch and it revved all the way up to 6000 just fine. Did it 3 times. So it's only bouncing while trying to accelelerate. I have a timing light and I'm going to check it tomorrow. But idk why it wouldn't do it with the auto ECU in it.
Old 08-01-2012, 07:54 AM   #29
shoguner
hahahahahah bandaids only get you so far..... just order a sensor of ebay or something like that.
Old 08-01-2012, 12:12 PM   #30
grimm199
grimm199's Avatar
Guys something amazing happened! I plugged A speed sensor in, and guess what! It still bounced off/cutoff at 5500! -__-
And if course our timing light trigger is messed up so we gotta find another timing light....
