Parts Shop MAX ~ Latest super low multilink suspension arms, rods, and chassis parts
The New tension rods are here!
These come with the same 1pc. forged steel end joint like our third generation RUCA. They have the yellow silicone dust covers and the new steel ball joint spacers as well. Steel locking nuts for the length adjustment are in place of aluminum from the previous model The anodized 6061 aluminum tube and end bracket are carried over to the new model. Hardware for the LCA is included. $200/pair ![]() ![]() ![]() ![]() It was getting to the point where I could not add any more pictures to our main advertisers thread, and it has been requested to make a separate G3 multilink thread due to the difficulty of navagating over 100 pages/3000 posts on the other one. Right now we actually have it all in stock so what better time to take action than now??? ![]() Our third generation arms and rods are stronger than ever. MAX multilink features more clearance for lowered cars than any other brand, as well as the adjustability you need to dial in your cars maximum performance. They let you set your personal preferences on characteristics like turn in, grip, tire wear and drift initiation. All of the MAX multilink parts are equipped with premium Japanese pillowball joints that eliminate OEM rubber bushings for a precision, predictable, tactile driving experience. The quality is on par with the best the world has to offer and the unique design features make them an unbeatable value. ![]() The MAX multilink can be complimented by using or famous MAX coilovers, Subframe Collars or Subframe Solid Risers, Super Steering Angle Knuckles, and IF tie rods for a perfectly tuned suspension setup. ![]() RUCA $200+sh In stock now! TOE ROD $200+sh In stock now! TRACTION ROD $180+sh In stock now! TENSION ROD $180+sh In stock now! SUBFRAME COLLARS $50+sh In stock now! SUBFRAME SOLID RISERS $100+sh In stock now! MAX R.U.C.A. (Rear Upper Control Arm) for camber adjustment on Super low S chassis cars ~100% TIG welded ~3mm/.120 wall thick DOM tube ~Single consistant bend keeps stress evenly distributed ~NMB Japan spherical bearings with dust covers ~50mm 1 piece forged rod end ~Powdercoat orange paint and Gold chrome finish on adjuster and rod end ~Angle union between adjuster tube and arm helps clear the chassis on lowered cars ~Upswept arm helps clear Axle boot on lowered cars ~Arm length maintains around -1 degree of camber on lowered cars with minimum adjuster thread exposure ~Compatible with any coilover brand *If your car currently has no adjustable multilink you must install RUCA and TOE together to adjust your rear alignment properly because in the S chassis when you change the camber it effects the toe setting. ![]() ![]() ![]() MAX Toe Rod ~Double TIG welded fork bracket ~31mm 6061 CNC amuminum adjuster tube is located far away from the subframe bracket for ease of adjustment ~23mm solid steel bend clears the subframe on extremely low cars ~NMB Japan spherical bearings ~40mm TIG welded rod end ~Orange and gold aluminum hard anodizing and Gold chrome steel finish *If your car currently has no adjustable multilink you must install RUCA and TOE together to adjust your rear alignment properly because in the S chassis when you change the camber it effects the toe setting. ![]() ![]() MAX Traction Rod ~Double TIG welded fork bracket ~31mm 6061 CNC amuminum adjuster tube ~23mm solid steel bend clears the subframe on extremely low cars ~NMB Japan spherical bearings ~40mm TIG welded rod end for S13 ~44mm 1 piece billet aluminum rod end for S14 ~Orange and gold aluminum hard anodizing and Gold chrome steel finish ~Increase traction by shortening this rod 1cm from stock length on higher cars or lengthen this rod for super low cars for correct geometry. *OK to install independant from any other suspension part. *27mm short and skinny wrench is recomended for ease of installation in cramped rod end/subframe area. We sell a custom wrench for $5. ![]() ![]() ![]() ![]() MAX Tension rod ~100% 6061 CNC aluminum construction ~NMB Japan spherical bearings ~44mm one piece billet aluminum rod end ~Plenty of adjustment length to safely set virtually any desired caster ~Orange and gold aluminum hard anodized finish ~Comes with new hardware for Lower control arm connection *OK to install independant from any other suspension part. *More caster creates a self steer feeling while drifing and less caster is good for cars equipped with our super angle steering knuckles. ![]() Subframe Collars ~CNC 6061 Aluminum ~Stiffens OEM bushing to eliminate wheel hop after clutch kick ~C shaped upper collars for easy installation ~Gold hard annodized finish *Can be installed independant of any other parts ![]() Subframe Solid Riser ~Completely replaces OEM Subframe Bushing ~Raises Subframe a half inch for lowered suspension geometry correction ~Makes more clearance to raise exhaust ~Slip fit, epoxy-it-in installation (no press needed) ~CNC 6061 Aluminum ~Gold hard annodized finish *Made specifically for low ride height vehicles to help fix roll center problem. *Please see our products forum for OEM bushing removal instructions *You must bend the E-brake cable bracket to reroute cable so it does not rub the driveshaft. ![]() Some history and the making of these parts: Here is a video of the arm that we make in the usa, slightly outdated now that we TIG weld this part ~ but still interesting. ![]() ![]() ![]() ![]() ![]() Adjuster, lock nut and pillowball spacer shown before finishing to reveal all steel components. ![]() After plating and dust cover installed: ![]() Installations ![]() ![]() ![]() ![]() Drift heaven Magazine. April 2009 ,Pg32~39 ![]() ![]() "simple parts but super important" "They all look similar but unique in their own way" Drifters change their nissan multilink arms for different reasons. "I don't like the stock rubber bushings", "I wanna be-able to do a proper alignment", "when I dropped my car, the stock arms didn't have enough adjustability", "I wanted it to look good". So which brand are you going to choose? These parts only consist of a shaft and a joint but each companies have their own theories about how they should be and what kind of material it should be. "Max believes in making parts for super low drift cars. They have a sister shop in USA and their friends and customers only desire to drift in super low drift cars. So their RUCAS and toe arms have special bend and angles to clear from the frame, subframe, knuckle, and axle boots. They also chose thick aluminum body to keep the weight down inside the wheels while maintaing its strength." ![]()
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! Last edited by DC Dan MAX USA; 11-04-2009 at 03:11 PM.. |
Thank you sirs
$620 shipped
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! |
![]() Join Date: Feb 2007
![]() ![]() ![]() Feedback Score: 4 reviews
I run PBM toe arms and I love them high quality shit. I'd going to be buying the solid subframe spacers do! This shit is the real deal. Thumbs up for PBM products!
Retired General
What can i say, this stuff is the shit!!! I have all the muli-link stuff. AMAZING.
I think i need those collars. ![]() |
![]() Join Date: Jan 2005
PBM stuff is awesome! I love the video of you guys building the arms! Just the fact that you went from MIG to TIG with out a crazy price increase says a ton about your company.
In case you are wondering guys even with very experienced TIG welders it takes more time to not only fit, but to TIG weld the arms. When the time comes PBM will be on my car. |
its great to see such transparency from a company who continues to improve their products instead of cutting corners saving a few bucks. ill definitely look to PBM when im ready to order some suspension arms, i already got the fender roller.
#13 | |
$790 shipped
no - we sell Ikeya tie rods - they are the best and they are only $120+sh ~ in stock now ![]() you can bend them in a U shape and they wont snap Quote:
The prices have been kept very low for a long time now despite many materials price increases because we know how cheap drifters are. This causes us to sell out of each run very quickly which makes having parts in stock a bit rare.
The Ikeya tie rods, that price doesn't include ends right? picture is throwing me off... how much for the ends? and can you use other ends or only Ikeya ends with those?
Marketing and event photographer www.natephoto.com XTC - Custom Paint and Body coming soon... |
#17 | |
The tenrod lever only? $113 shipped the standard hydrobrake complete is $245 shipped the inners are $133 shipped to you
#21 |
Just sent you guys an email, tried calling but I guess you guys are off today
![]() Can't wait to get one of those new swirl pots!
#22 |
just installed all my new goodies. all i can say is WOW.
now i need some subframe risers. |
#24 |
![]() Join Date: Nov 2008
Location: NORCAL - SAC NOT Bayarea NOT So Cal NOT Anywhere Else! JUST SACRAMENTO
god
powerd by max is the fucking sex
![]() My WHITE WHEELS are 15x11 -46 STOP ASKING! |
#26 | ||||
Send payment to [email protected] on www.paypal.com
Please write the item description in the "Email to recipient" notes section $1078 shipped, there is a 2 month wait Quote:
#28 | |
![]() Join Date: Sep 2007
Trader Rating: (25)
Definitely some of the best stuff out there. I can't wait to get my coilovers on!
How much for S14 tie rods, S13 RUCAS and S13 tension rods minus my current $29 positive balance shipped to 17517?
