02-23-2011, 08:29 AM | #302 | |
Will do
My +700hp RS13 |
02-23-2011, 08:33 AM | #303 | |
Hang on, more to come
My +700hp RS13 |
03-05-2011, 12:17 AM | #306 | |
03-08-2011, 08:59 AM | #307 |
I have one Bosch 040 intank to feed a swirl tank and these two 044 inline to feed the rail.
My +700hp RS13 |
03-16-2011, 08:02 AM | #308 |
Todays visit at Creatix resulted in a couple of spare insert for the two AEM-fuelfilters and an oil filter relocation kit. Good size with the AN10-connections.
My +700hp RS13 |
03-25-2011, 05:28 AM | #310 |
I've finally got hold of a really good and durable aluminum jack that is sufficiently low and deep. Works great everywhere, both in the garage and to bring to the track events.
* Heavy Duty 1814kg (1.8 tons EU) (2 US Tons) Capacity * Side Mounted Handles (easy positioning) * Quick Lift Design - 5 Pumps to Top * Wide Track Wheels & Castors * Rubber Saddle Pad Protects Vehicle * Foam Bumper Handle Pad Protects Hands & Vehicle Dual Return Springs * Low Lift Height - 89mm * High Lift Height - 498mm * Overall Length - 673mm * Chassis Width - 330mm * Handle Length - 1350mm * Weight 22kg Arcan Jack
My +700hp RS13 |
03-27-2011, 01:50 PM | #311 |
Some more in transit
My +700hp RS13 |
04-11-2011, 10:10 AM | #312 |
A bunch of injectors from Injector Dynamics.
2200cc and high ohm. Perfect for E85
My +700hp RS13 |
04-12-2011, 09:53 AM | #314 |
WOW, this is just plain fabulous . Top quality parts for a uber high grade CA build. Many try but fail but you take the cake here. Nice build lets see some videos. You need a Gopro camera
FRIENDS DONT LET FRIENDS DRIVE STOCK 1992 Coupe SE |
04-30-2011, 07:15 AM | #316 |
Thank you guys
Zef Engineering is an excellent supplier This will help in the pursuit of weight saving
My +700hp RS13 |
04-30-2011, 08:51 AM | #317 |
The jack has been tested successfully.
Mounted some of the braces from Ultra Racing. They are spot on. 50mm rear over fenders. At the time being lots of Camber to adjust. Original fenders shall be partly cut away and welded and then all body parts will be glued in their final places.
My +700hp RS13 |
04-30-2011, 10:07 AM | #319 |
The best CA build I have ever seen, lets get some video footage of that monster!!!!!!!!!!
WARNING: User has a low tolerance for stupidity. Post at your own risk. |
05-01-2011, 10:11 AM | #320 |
Thanks mates. Video will come when things are ready. Some more work to do
The front end of the car has appeared rather empty for a while but now I have picked up the front bumper at Thomas paintshop (well done Thomas). I will cut away som minor areas inside the opening to make a snug fit for the intercooler but would anyway like to show you some quick motivating pictures.
My +700hp RS13 |
05-01-2011, 10:46 AM | #321 | |
not giving a fuck
Trader Rating: (104)
Feedback Score: 104 reviews
LOL 240... whats better than 1? 5 1's ...lol PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r |
05-01-2011, 10:49 AM | #322 |
It a good idea. Easier to work with the engine and keep things clean
My +700hp RS13 |
05-02-2011, 10:01 PM | #324 |
Please do.
It's a lovely time of the year too. Lots of nice rides on the streets.
My +700hp RS13 |
05-19-2011, 09:48 AM | #325 |
One is not enough... 16pcs
My +700hp RS13 |
05-20-2011, 09:07 AM | #326 |
Looks empty now that the wheels are sold. Well, the new ones will soon enough be mounted
Meanwhile I search comfort from a really fat cat
My +700hp RS13 |
05-25-2011, 12:49 AM | #327 |
To match the size of the fuel lines and the huge fuel flow, I decided to invest in a Turbosmart FPR-2000 with AN8 fittings.
My +700hp RS13 |
06-14-2011, 07:04 AM | #329 |
Improved braking dynamics.
I sorted a 1" BMC from Tokico in Japan. It gives a perfect feel to the brakes.
My +700hp RS13 |
06-29-2011, 09:31 AM | #330 |
It is time to make the fuel and oil lines.
12 meters of stainless steel braided Teflon line for E85 with 40pcs AN8-couplings and 6 meters of stainless steel braided oil hose with about 10pcs AN10-couplings.
My +700hp RS13 |
