Old 02-21-2011, 08:33 PM   #31
BoostSlideWayz
BoostSlideWayz's Avatar
BoostSlideWayz is an unknown quantity at this point
Send a message via AIM to BoostSlideWayz Send a message via Yahoo to BoostSlideWayz
Just a tip... have that manifold braced on the flange.... when that thing is hot its gonna need support.
1994 toyota supra...... n-a D=
1992 nissan 240sx KA24E-T fully Built =D
BoostSlideWayz is offline   Reply With Quote
Old 02-23-2011, 02:48 PM   #32
NismoTuner21
NismoTuner21's Avatar
NismoTuner21 will become famous soon enoughNismoTuner21 will become famous soon enoughNismoTuner21 will become famous soon enough
Plan on it, thanks!
Got some more stuff in.
Driftmotion Thermal Intake Gasket to drop air intake temps.
Driftmotion Pulley set, which I had to buy since I upgraded to a 2JZ water pump.
New Accessory belt for no A/C, God this was easy to put on compared to VG's, lol.
New Action 6 puck clutch.
New OEM Pressure Plate, pilot bearing, and and clutch bearing.
Installed new belt and pulleys.
Then I cleaned and masked off the upper intake manifold for paint.
Primed.
With two coats, gonna do a couple more tonight.
And also gonna install new valve cover gaskets and bolts.
NismoTuner21 is offline   Reply With Quote
Old 02-23-2011, 03:36 PM   #33
tricky_ab
tricky_ab's Avatar
I love where this build is going!
Old 02-23-2011, 05:07 PM   #34
UNITEDMASTER
UNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to all
Are you gonna run a heater,if not delete the hard line on the water pump. Otherwise its lookin real good,carry on!!!!
MR JACKSON.
UNITEDMASTER is offline   Reply With Quote
Old 02-23-2011, 05:09 PM   #35
NismoTuner21
Nope I'm not ^^
I'm gonna cut the nipple and weld it shut on the hard line, then the nipple from the block I'm gonna plug up. Do you know if that's gonna stop any flow?
Old 02-23-2011, 07:50 PM   #36
UNITEDMASTER
I usually make a block off plate at the waterpump.Flow is fine.
Depending on how you have your radiator set up you can put a -4 fiting on block off plate ,and run a line to your fill pot.
Or just cap it & have a handy block drain!!! & it can be helpfull when bleeding the cooling sys.
MR JACKSON.
Old 02-23-2011, 10:44 PM   #37
NismoTuner21
Yeah but doesn't that tube feed the oil tree for cooling? Or do you run the hose that originally went to from the oil tree to the tube from the oil tree to the nipple on the block for the heater core?
Old 02-23-2011, 11:22 PM   #38
inferno s14
inferno s14 is making his/her stupidity well-knowninferno s14 is making his/her stupidity well-knowninferno s14 is making his/her stupidity well-knowninferno s14 is making his/her stupidity well-known
Respect!..your z is gonna be fire kid straight up no doubt..keep it up.
inferno s14 is offline   Reply With Quote
Old 02-26-2011, 07:51 PM   #39
UNITEDMASTER
Ditch the OEM style cooler. Order a oil cooler sandwich plate kit for a ford 8 cyl from Summit racing & go external cooler
MR JACKSON.
Old 03-10-2011, 09:14 AM   #40
NismoTuner21
Sooo I finally did some real work. Yanked all of the shit out from under the dash in preparation of cutting the firewall, and also stripped the bay of everything I won't need except the clutch line. I have almost every piece I need for the engine/trans. From here on is where the fabbing begins. I plan on backing the motor up about 4-4.5 inches from it's current position. From there, I'll get the driveshaft made, then the I/C and rad setup done as well. Then wire everything up and slide :driving:
Pics:
New valve cover gaskets and bolts.
Starter and more shit installed.
Peep my sweet paint job, cause I'm a ricer.
Cleaned up the fuel rail and installed new seals.
IACV
SOME of the shit that was removed...
But a lot was yet to be removed.
In the process of stripping under the dash, there was soooo much shit... lol
After that I started working on the bay again.
Almost everything was out in this pic
Then I put the motor in just to get some measurements and see the fit. I will be able to keep my windshield wipers and brake booster!! w0000! Now I just have to figure out what I'm gonna do with the downpipe
For the lulz
Old 03-10-2011, 11:25 AM   #41
thenooblet
thenooblet's Avatar
thenooblet is an unknown quantity at this point
lawl^
Texas does LS's hard
thenooblet is offline   Reply With Quote
Old 03-10-2011, 11:33 AM   #42
Rockogtr
Rockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the rough
Send a message via AIM to Rockogtr
Looks good so far man keep up the good work
Rockogtr is offline   Reply With Quote
Old 03-10-2011, 12:19 PM   #43
Z32TT-R
Z32TT-R's Avatar
Z32TT-R is an unknown quantity at this point
Lookin good Sal, get er done!
Z32TT-R is offline   Reply With Quote
Old 03-10-2011, 12:24 PM   #44
K_style
K_style's Avatar
Trader Rating: (63)
Feedback Score: 63 reviews
Looking good !!!
Can't wait for outcome..
Old 03-14-2011, 11:35 AM   #45
harangatang
harangatang's Avatar
harangatang can only hope to improve
Finally, I see someone appreciating the awesome-ness of 1J's Your turbo setup is pretty close to what I'd like to do... just wish someone made a TS housing for the PT5857... cause the 62+'s are way more hp than I'm looking for lol.
Motor looks really nice after your clean up! GL with the build buddy. Can't wait to hear this beast running.
Tyler
harangatang is offline   Reply With Quote
Old 03-14-2011, 11:39 AM   #46
4DOOR_LIFE
4DOOR_LIFE's Avatar
Definitely keeping my eye on this build. good stuff so far man, can't wait to see vids of this bad boy running.
Instagram: @Elegant.Company
Old 03-14-2011, 11:47 AM   #47
kraven9
kraven9 is an unknown quantity at this point
Nice build. It looks good so far.
kraven9 is offline   Reply With Quote
Old 03-14-2011, 06:08 PM   #48
NismoTuner21
Thanks guys! I can't wait to see it running/crashing into shit either!!!
Looks like I'm not gonna be doing firewall modifications due to FD rules Trading a local dude for a front sump oil pan sometime this week. HOPING to get the motor and all that mounted by this weekend
Old 05-01-2011, 05:02 PM   #49
JDMtyteYO!
JDMtyteYO!'s Avatar
JDMtyteYO! is an unknown quantity at this point
SAL!...please dont use that plastic plenum gasket...theres a reason why the stock one is metal! trust me i made the same mistake and wasted 70 bucks or however much that DM one is...also.....im trying to work out a deal with chris who has my 1j fc !!!!!! if i cant get the whole car he was talking about selling the motor swap but id rather have the whole car lol
glas to see this things coming along even tho your last post was a month ago (palm to face) i fail
JDMtyteYO! is offline   Reply With Quote
Old 05-04-2011, 10:41 PM   #50
NismoTuner21
Coming along reallllll slow. Motor and tranny is now mounted with no firewall mods. Oil pan sits about .25" above the crossmember and shifter needs to be extended about six inches. Driveshaft and shifter extension will be done this week.
Hood has plenty of clearance, and I didn't even notch it!!
Stock pan
Modded pan to clear the cross member and sway bar. Lost a little more the half a quart of oil doing this, but I'm getting a huge oil cooler, lol.
Started stripping the rest of the interior for the cage. Dash is loose and all the A/C shit is gone.
Working on slimming the engine harness since I'm using the F-Con and won't need a lot of these BS sensors.
Got the oil feed line made with stainless fittings and teflon coated SS line, just need a
-10 fitting and some SS line for the return, and the turbo coolant lines as well. Intake side is all installed except for throttle body. Also, I plugged up all the useless water/heater core nipples.
That's it for now, more coming soon!!! F-Con jumper harness is on the way and I think I figured out what I wanna do for my gauge cluster setup.
Old 05-04-2011, 11:25 PM   #51
deathrace2000
deathrace2000's Avatar
deathrace2000 is an unknown quantity at this point
This is a cool build.
irony.cc
deathrace2000 is offline   Reply With Quote
Old 05-05-2011, 02:02 PM   #52
NismoTuner21
Thanks d00d!!
Old 05-05-2011, 04:16 PM   #53
pandaroo
pandaroo's Avatar
pandaroo is an unknown quantity at this point
lookin good... lookin real good.
89 2tone coupe
2jzgte swap in progress
pandaroo is offline   Reply With Quote
Old 05-05-2011, 04:35 PM   #54
speedfreak90
speedfreak90's Avatar
speedfreak90 is an unknown quantity at this point
this looks quality. good job dude. cant wait to see this bad boy terin it up
speedfreak90 is offline   Reply With Quote
Old 05-05-2011, 04:53 PM   #55
irritatedmax
irritatedmax's Avatar
irritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enough
That looks real sick in the bay.
BRICKHOUSE PRODUCTS
IG @brickhouse_products
irritatedmax is offline   Reply With Quote
Old 05-06-2011, 06:26 PM   #56
JDMtyteYO!
JDMtyteYO!'s Avatar
yeah...i gotta sell my s13 and buy my fc back i hatche jooo so much!
Old 05-06-2011, 07:47 PM   #57
iHeartTheTouge
iHeartTheTouge's Avatar
iHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfection
Very nice! You dont see enough baller Z32s IMO. I wish I went 1JZ instead of LS1 Fucking awesome motors
Slide 'n Hide
-'72 240z LS1 project
iHeartTheTouge is offline   Reply With Quote
Old 05-07-2011, 10:49 AM   #58
UNITEDMASTER
Great to see the update,looking good ,seems to be moving along well.
Glad to see you didnt cut the firewall.
MR JACKSON.
Old 05-07-2011, 12:24 PM   #59
NismoTuner21
Thanks man! I can't wait either!
Lol, But I <3 yew!! And you need to do that.
I completely agree. I can't wait to make my car look bauce again.
Thanks man, I wish it was moving faster I was hoping to drive XDC on May 15th.. I'm definitely gonna drive RD.3 FD/SWD pro-am on July 3-4 though. Car goes in for the cage next week!!
Old 05-07-2011, 11:10 PM   #60
irritatedmax
People always say Z32's are heavy. How light can you get them stripped and caged?
BRICKHOUSE PRODUCTS
