Old 09-01-2015, 05:56 AM   #1
asweat97
asweat97 is an unknown quantity at this point
S14 SR20det ECU WC wiring
Hey everyone I'm having to wire my own MAF plug, just the stock one because somehow my harness didn't have it. I'll attach below an image of the pin out but I am unsure if I did it correct so if someone could advise. I used pin 26, and 27. I tried tapping the 12 volt into the ecu relay (pin 16) since it pushes 12 volts but now my car won't start only cranks. However it could be unrelated.
WAS UNRELATED, SPARK PLUGS HAD JUST HAPPENED TO GO OUT!!
asweat97 is offline   Reply With Quote
