![]() Join Date: Mar 2009
![]() ![]() Bought everything separately getting this 240 rolling. 92 shell chuki 93 ka24de apexi stg 2 clutch I did the engine mounting and all the wiring myself. After the whole car was complete the car turned on first crank no problem. After the test drive and a car wash the car just died on me. The car appears to be dead. *clutch started *used jumper cables *starter works, by using the jumper cables directly towards the battery in the positive poll. *Gas pump, radio, and starter are not getting power. * made sure the harnesses are grounded * check fuses all works except for two but replaced with two working one but dont get 12 volts back when i test it with a volt meter. I am officially with a headache towards what it can be. |
Tags |
battery, electrical harness, fuel pump, ground, ignition |
