01-03-2009, 02:49 PM | #91 | ||
Glad you've already got some other things, but you realize those could all go on a SR with just a head gasket and make WAY more power, right? Quote:
Like I said, find me one person that's gone from SOHC to another engine (any engine) and likes the SOHC better.
01-03-2009, 03:49 PM | #92 | |
1994 toyota supra...... n-a D= 1992 nissan 240sx KA24E-T fully Built =D |
01-04-2009, 12:28 AM | #93 |
I went from sr20det to a ka24e and i love that motor done 3 events on it with know problems ran HTM with it....
I think it ie a great motor to start on and learn how to drive becuse if you can drive with it and get good just wait till you get some power. |
01-04-2009, 12:53 AM | #94 | |
1) You went from SR to KA-E because you fucked your SR, right? 2) Driving a turd to become a better driver is not the topic of this conversation.
01-04-2009, 01:05 AM | #95 |
I would say to do this as a parts list.
Bottom End Assembly Ishihara and Johnson crank scrapper and windage tray Bullnose and knife edge crank shaft (drops about 3 lb.s) eagle rods cp pistons (9.0:1 CR) datsun/nissan L28 oil pump, or TOGA HV oil pump bearings seals/gaskets Top End Assembly solid adjustable lifters Crower camshaft .020 valve enlargement on exhaust valves .010 valve enlargement on intake valves Port and extrude intake ports seals/gaskets Bolt on modifications Chromoly or aluminum flywheel exsessive intake manifold JGS exhaust manifold HX35 holset turbo silvia intercooler 1G blow off valve platinum spark plugs stage 2 clutch kit electric fan kit Fuel management 440cc injectors top feed project silvia top feed fuel rail or honda prelude fuel rail circuit sports 255 fuel pump fuel pressure regulator engine management enthalapy tune boost controller turbo timer N60 MAF
01-04-2009, 01:46 AM | #96 | |
01-04-2009, 10:22 AM | #97 |
Half of you guys in this forum are idiots.
Boostslidewayz wants to build up a KA24E-T. I would rather go with the ka24de, or VQ myself but that is my preference, just as the KA24e is his prefrence. Any way it comes down to most of you clowns don't understand the heritage behind some of the greatest racing engines of all times. your stuck in your little wanna be drifter lifestyle's where sr's are the shit, KA's suck attitude. Half of you guys in this forum need to get your head out of your asses. The KA engine has been used in more US motorsports than the sr has. But then again most of you kiddies are stuck watching Initial D, or the touge challenge. It's also been built to hold down more than 300WHP naturally aspirated. Almost 600WHP boosted for the ka24(e) Over 900WHP for the KA24(de) On a naturally aspirated build the KA is cheaper than the sr. On a boosted build sure it cost a little bit more to build up the KA. When it's all said and done though chances are it will make more power than the sr that came F.O.B. Help this guy out with his build, have some positive things to say or get the fuck out. In the process you are just ridiculing him when you talk down to his ideas, it makes all of you pieces of shit.
01-04-2009, 11:01 AM | #98 | |
yeah yeah.... talk talk talk.
the ka24e is still a big pile of shit. i owned one WAY too long to know. of course, put money into it and im sure you can make it a much better motor, but at what cost? i believe its wise to research these costs before dumping money into a fucking SINGLE CAM MOTOR. twin cam is the way to go. Quote:
01-04-2009, 04:09 PM | #99 |
I know the owner of the car (at that time) and the owner of the shop it was at. That's what the shop owner told me. LOL, it blew black clouds too, it was tired as fuck. as they tend to be.
01-04-2009, 04:17 PM | #100 |
Trader Rating: (24)
Feedback Score: 24 reviews
Since I actually did all the research, spent the money, did the build, drove it for 9k miles or so, then sold it (and bought an SR), I DO have room to talk. I would just recommend going a different route. Without a lot of headwork the motor chokes off sorta quick, leaving you with a somewhat limited powerband.
Heritage means fuckall in this instance. The racing single cams were like 14:1 comp motors that lasted for 24hr between rebuilds. Yes they made huge power with sidedrafts carbs, but that's not the goal here. Single cam turbos have also put down like 720whp, but that's not to say that any ol' motor can make that kind of power, even without figuring in the reliability aspect. In any event, to the OP, good luck if you pursue this route. You WILL learn a lot but you will also spend some decent coin if you do it right. |
01-04-2009, 05:43 PM | #101 |
I do plan on spending my money on top quality parts and having a shop help me/guide me the right way so i have a some what reliable motor. im sure 330HP wouldnt be too hard on the SOHC would it??
Im hearing almost equal amounts of oppinions about how the KA is good and bad but ive got some good info on the motor so i think i might just build it... I plan on ordering the parts soon for the bottom end. then ill have the head ported,stage 2 cam, valve train etc. maybe even upgraded intake manifold ha. thad be cool in my eyes. Thanks guys for all the info and opinions i greatly appriciate it and will use everything youve told me and keep it in thought when im doing the build... thanks again -Kody
01-04-2009, 05:56 PM | #102 | |
OP....DO it... also as it is built correctly (aka take your time, double check, triple check everything) then it will hold up great....
01-04-2009, 08:27 PM | #103 | |
Think outside the BOX. You can build a single cam actually cheaper than what it takes for me to get my dual cam parts. It's cheaper to build a SOHC than it is to build up an sr20. Theres an abundance of parts from the nissan parts BIN (L28, NAPSZ) that can be modified for the KAE, not the KADE which is cheaper nd better. the only thing I don't like about the SOHC is that it uses lifters.....Oh what a minute........Isn't that a motherfucker, the sr20det uses piece of shit lifters also... The only shitty thing about the sohc on any realistic level is that you can't adjust valve overlaps like you can with the DOHC. Also without solid lifters it's limited to it's rev range of about 6800RPM. Other than that you can port the living shit out of it, get mopre flow out of it than a DOHC, use larger valves and call it a day.
01-04-2009, 08:42 PM | #104 |
go for it
if more people, like yoursel,f build up the sohc for turbo, maybe big brand names (trusted) will make more and even better parts for the motor, as they have done for the dual cam KA's
dying is only living, dying to live |
01-05-2009, 01:28 AM | #105 |
Good news guys, I should be ordering the parts tomorrow. The bottom end parts that is..
Do you think the stock crank can handle 300+ ?? i would like to have room for more HP later on when i need it. parts tomorrow should be: pistons... O & J Performance KA24E/DE Pistons I was thinking 89.5mm 8.8 CR for the pistons ? let me know what a better C.R. should be best for my application rods-eagle- O & J Performance Connecting Rods crank bearings- O & J Performance Engine Bearings rod bearings and later on when i get alittle more money ill start on the top end. thanks guys
01-05-2009, 01:34 AM | #106 | |
lol why thank you, its alot better than when i first got the car.. 1992 nissan 240sx BIG project Video by KODY-T.S.W - MySpace Video ^ lol im not crazy i was just excited i got it for 800 bucks. it had a front end but i took it off to do the S15 conversion Then 4 maybe 5 months later lol long time and it still ran ruff. Sea Foam Nissan 240SX Video by KODY-T.S.W - MySpace Video LOL i am not proud of these videos what so ever but i think there funny
01-05-2009, 01:43 PM | #112 | |
KA-T.org - The Home of 1000+ whp/7 sec Turbo KA's - they have a whole section dedicated to SOHC motors and contrary to all these JDM SR fan boys KA motors both DOHC and SOHC can handle power very nicely and will easily embarrass an SR. |
01-05-2009, 01:44 PM | #113 |
that scca car gave me bones
Drift Indy |
01-05-2009, 01:52 PM | #114 | |
01-05-2009, 02:17 PM | #115 |
Heres a sexi car, even though its running a DOHC KA:
KA-T.org - The Home of 1000+ whp/7 sec Turbo KA's But getting back to sexi SOHC KAs: |
01-05-2009, 02:36 PM | #116 |
mmmmm i see some awesome looking cars on here..
deffinatly way more fun to look at then seeing an SR everytime.
01-05-2009, 04:34 PM | #118 |
Lol, this started out as a discussion of what was cheaper to get what you want done.
Now it's a parade of high-$$$ Ka-T's, and you're doing exactly the opposite of what everyone said to do (you're buying parts piecemeal, instead of waiting until you get all the $$$ and then making a decision). I'm unsubscribing and going on with my life.
01-05-2009, 05:02 PM | #120 | |
