Old 10-27-2015, 10:11 AM   #1
Turb
Turb's Avatar
Turb is an unknown quantity at this point
Vacuum reading
Okay so I'm looking to buy a 240 with an sr20 red top has a hks blow off valve if that matters and I was wondering if -17 vacuum is really low, like if it has boost leaks? Thanks in advance
Turb is offline   Reply With Quote
Old 10-27-2015, 10:54 AM   #2
KAT-PWR
KAT-PWR's Avatar
You should boost leak test it regardless.
MRP Manufacturing
Old 10-27-2015, 11:29 AM   #3
Turb
Turb's Avatar
I may sound like a complete retard but how do I do that?
Old 10-27-2015, 11:38 AM   #4
bmxer882x
bmxer882x is an unknown quantity at this point
Get a pvc cap, drill a hole in it.
Put a valve stem in the hole.
Put it in the coupler hot side of the turbo.
Hook air compressor to valve stem.
Apply air (boost) to system. Listen for leaks.
Also, my sr idled at -18 with no issues.
bmxer882x is offline   Reply With Quote
Old 10-27-2015, 01:12 PM   #5
KAT-PWR
KAT-PWR's Avatar
He means attach it to your cold side intercooler piping, but this is correct.
One of my friends had an aluminum 3" hose end welded to an NPT fitting that threads onto a digital tire pressure unit so he can fill to specific psi and check for leaks. Pretty neat.
MRP Manufacturing
Old 10-27-2015, 01:19 PM   #6
Gingersmurf
If you're just looking for leaks in your intercooler piping, etc. Use the cap method, and hook up it up to an air compressor to like 5-10PSI and spray soapy water to all the couplers and if there's a leak, you will see bubbles forming
Old 10-27-2015, 01:26 PM   #7
Turb
Turb's Avatar
thanks for the help guys!
