Old 01-22-2010, 09:20 AM   #1
ZilviaBot
Zilvia.net Bot
Post Forge Motorsport Release Intercooler Upgrade for Nissan GT-R
01-22-2010 01:49 AM
Forge Motorsports have finally released their anticipated intercooler upgrade kit for the Nissan GT-R. The upgrade turns the tables on the conventional GT-R intercooler design. Instead of two cores side by side this uses one long tube and fin core above another in a single long unit. The core size is 740mmx250mmx100mm. The benefits of this design are a greater overall volume and reduced pressure loss versus the standard intercooler. Overall the whole setup actually works out lighter than standard also with around 0.9kg shaved off the cooler and pipework setup.
In terms of performance improvement, Forge Motorsports noticed more area under the curve when dynoing this against a stock intercooler with improved cooling as well. With the standard cooler air intake temps were around the 43 degree C mark, with the Forge Motorsport cooler this dropped to 32 degrees C.
Everything you need for installation is included in the kit at just £1,800 GBP plus shipping. For UK residents that price is minus VAT.
Thanks to Ben @ GTC-R for the tip off.
Link: Forge Motorsport R35 Intercooler Product Page
View Entire Article: Forge Motorsport Release Intercooler Upgrade for Nissan GT-R at GTRBlog.com Originally appeared on and © GTRBlog.com. 2010. | Read comments.
More...
HTML code is On
