HELP with my sr20?
Well when I turn it on it sits around 1000rpm then after a couple of mins bogs and dies. But if I give it gas or drive it, it stays alive, but at like a stop light it does the same thing, so I have to give it gas. I checked all the vacuums and inter cooling piping but everything seems to be in tact. I have a sohc fuel pump could that be the problem? Or any what should i do?
Dont guess when it comes to troubleshooting your car, you should figure out exactly what the problem is before you start replacing parts.
my guess you still have a vacuum leak somewhere or you need to adjust your IACV. |
Ok i installed the new walbro, but it does the same thing, and i noticed it kind of shakes alot? it stays alive now when it warms up, but what else can it be? I checked all the vaccum lines also...???
