Old 11-18-2009, 09:16 PM   #1
nathanong87
nathanong87's Avatar
Weird idle characteristics while braking (?) ....
essentially when i'm in 3rd/4th gear and around 3k rpms, i take the car into neutral and pull to a stop while braking. When i do the above, my rpms drop down to near stalling.
when i simply coast (not applying the brake), my idles go from 3k to 700-800 (which i think is "normal")
i am thinking it's yet a vacuum leak somewhere, but i just wanted to see what some of you gurus thought about this. I'm no expert by any means.
thanks in advanced!
Old 11-18-2009, 09:26 PM   #2
AznXstazy
AznXstazy has a little shameless behavior in the past
sounds like the ivac. try cleaning it.
AznXstazy is offline   Reply With Quote
Old 11-18-2009, 09:35 PM   #3
M11's
M11's's Avatar
M11's is an unknown quantity at this point
for sure check for vac leaks. iacv, clean maf, clean in throttle body. Bed its vacuum tho.
M11's is offline   Reply With Quote
Old 11-19-2009, 04:58 AM   #4
nathanong87
thanks, i'll check the IACV for sure. i mean it's more annoying that not
Old 11-20-2009, 04:44 PM   #5
Mangudai
Mangudai's Avatar
Mangudai is an unknown quantity at this point
Do you have an auto ecu?
Almost there.
Mangudai is offline   Reply With Quote
Old 11-20-2009, 05:14 PM   #6
Ceepo
Ceepo's Avatar
Ceepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enough
are you ka or sr?
In my sr20det(redtop) when i press the brake the car wants to die, imo i think its the current draw to the lights putting a load on the alternator and causing the motor to go sluggish for a second while the ecu kicks up the rpms, all my freinds cars do it... Sounds like a pretty good theory to me lol...
Ceepo is offline   Reply With Quote
Old 11-24-2009, 12:28 PM   #7
nathanong87
negative
Originally Posted by Ceepo View Post
are you ka or sr?
SR, i also contemplated this theory as music is being played really loud, headlights are often on, and braking will bring up the brake lights. HRMMMMmmmm
HOWEVER, i believe that the car is "stalling" whilest stopping quickly, which will disprove the brake lights having to play a factor. I can brake slowly while in neutral and come to a stop withtout the engine's RPMs dropping suddently to "0"
Old 11-24-2009, 02:34 PM   #8
nothix
nothix's Avatar
nothix is an unknown quantity at this point
are you ka or sr?
had this same exact issue. Ran a ground cable straight from the battery to the brake light ground (battery is in the trunk) and problem is completely gone. Give this a try.
as for dieing without pressing the brakes. Check for vacuum leaks, clean TB and IACV, and recirculate your BOV.
'89 Sil80, SR20DET, GT2871r .64
nothix is offline   Reply With Quote
Old 02-07-2010, 02:54 PM   #9
nathanong87
just re-visiting this thread, but i found out it was a small small small boost leak near my FMIC couplers
natelife.tumblr.com
