Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Specific Topics > Archive and FAQs
Archive and FAQs Archives and Frequently Asked Questions about the 240SX are in here.
Old 10-15-2005, 06:30 PM   #1
sil80phobia
sil80phobia is an unknown quantity at this point
so I fixed my smog issues with high nox..
Just figured someone might find this useful.
So my 95 S14 failed smog last week, just BARELY. Bone stock except for Injen CAI. My car is EXTREMELY clean and well maintained, so it pissed me off.
Max allowable NOX was around ~700/736 ppm for idle/25mph tests. I was testing 710/745 .. just a hairs breadth from passing. Based on my calculations, I only needed a ~2% improvement to pass.
1. first thing I did was inspect the EGR setup. Not surprised to find the lower EGR vacuum line rotting. (pretty common as I've searched). So that and the FPR line was replaced with silicon tubing in short order
2. I had timing at 20.3 degrees when it failed. They allow +/- 2 degrees so I backed timing down to 18 degrees.
3. I unplugged a vacuum line and ran an entire can of intake/throttle body cleaner through the engine at 3000 rpm.
4. Drove around a week with a bottle of guaranteed to pass in the gastank (with 91 octane as I've read it helps lower NOX) for a week.
5. overinflated the rear tires to minimize load on the dyno. also had less than an 1/8 of a tank of gas and I emptied my trunk and took out my spare - not sure any of this did anything, but someone had suggested it - anything to get me that 2% margin I needed to pass!
6. changed my oil.. was due anyway.. all in the name of minimizing load on the engine..
7. drove the piss out of the car for about 20 min (nice sustained 5k RPM canyon run) prior to testing
The results blew me away. I was hoping for a 2% improvement on my previous 710/745 result. What I pulled off today was 77/92 !!! thats right.. 77/92, not a typo. Essentially 30 min of my time and $10 in stuff. Didn't touch my 02 sensor, left my original 165k mile cat on.
Good info. Archived. -Kevin
Dave
sil80phobia is offline
