Old 03-25-2011, 11:03 AM   #1
SGTRanger175
SGTRanger175 is an unknown quantity at this point
Repinning SR20DET F4 plug, missing wires. Pictures inside.
As the title says, I'm prepping to repin the F4 plug to get the car running. So I am labeling all the wires and will be pulling them all out. Then just repin the entire plug.
I am following this diagram ( http://garage-c.com/techdocs/s14wiring.doc ) to repin the F4 to match the M63 (USDM Jan-97 240SX S14).
However there are a couple of wires that is missing from the Silvia OE S14 F4 plug. Where would these missing wires be located?
Now there is an extra white plug (rectangular) that I suspect is the F7 plug. Are the missing wires I require in the F7 plug. Because the USDM harness does not have anything that plugs into the JDM F7 plug?
Here are some photos of what I am talking about, all photos are thumbnails so you can click on them for a full size image.
JDM S14 F4 plug. The missing wires are 8, 14, 15, 18, 29, 31, 32, 38-40, 41-44, 46, and 47.
This is the plug that I believe is the F7 plug.
SGTRanger175 is offline   Reply With Quote
Old 03-25-2011, 12:14 PM   #2
SGTRanger175
Updated.....
The F7 plug is for ABS. So if you dont have ABS you wont have a connector for it. So just tape it off and out of the way.
Old 09-28-2012, 07:55 AM   #3
drftnissan
drftnissan is an unknown quantity at this point
Send a message via AIM to drftnissan Send a message via Yahoo to drftnissan
Did you ever get your wiring figured out? I have the same issue with my F4 plug.
Any help would be awesome...
drftnissan is offline   Reply With Quote
