Old 07-27-2008, 05:13 AM   #1
rb25_s13*CHUKI
rb25_s13*CHUKI's Avatar
rb25_s13*CHUKI is close to perfectionrb25_s13*CHUKI is close to perfectionrb25_s13*CHUKI is close to perfectionrb25_s13*CHUKI is close to perfectionrb25_s13*CHUKI is close to perfectionrb25_s13*CHUKI is close to perfectionrb25_s13*CHUKI is close to perfectionrb25_s13*CHUKI is close to perfectionrb25_s13*CHUKI is close to perfectionrb25_s13*CHUKI is close to perfectionrb25_s13*CHUKI is close to perfection
Send a message via AIM to rb25_s13*CHUKI
Clutch is my starter now
I just put together my other s13 and took it up to crest this friday. I was driving and everything was fine until i hit a bump. Once i hit the bump my car started acting up. One head light stopped working and started going up and down. then the clutch turned into my starter.. I put in the key and turned it just to where the radio will go on and i push the clutch in and it starts the car.
I'm really Really sick right now so if you guys could give Ur info on this so when I'm better i can fix it.. "
Basicly my clutch is now my ignition.. I can take my ket out and the car will stay on.. The key doesn't start the car anymore the clutch does.. When i put the clutch in to shift the starter cuts on
Obliterate
rb25_s13*CHUKI is offline   Reply With Quote
Old 07-27-2008, 06:20 AM   #2
mad-ass
mad-ass's Avatar
do you have an alarm? obviously it's some wiring problem. take a look at your ignition wirings man, that's the only advise i can give you.
good luck
Old 07-27-2008, 04:23 PM   #3
drftthatshit
drftthatshit is on a distinguished road
fallow the wires down from the ignition in the car where the key goes see if maybe ur clutch peddle is grounding out the starter selinoid and starting the car
drftthatshit is offline   Reply With Quote
