Old 11-23-2016, 12:33 PM   #1
gripROYAL
gripROYAL's Avatar
gripROYAL is an unknown quantity at this point
GRIP ROYAL GARAGE CLEANOUT: Kaaz, SR20 BC cams, SPEC KA, Digi Climate, RB25 Parts, +
We've accumulated a lot of spare parts over the years and we're running out of space! PayPal Only. Prices include shipping within the US. Keep an eye out, we'll be adding to this as we dig deeper into the shop...
Engine/Drivetrain/ECU
VH45DE ECU (A18-B12 P74; 93 Q45 w/ traction control) - $45
VH45DE ECU (A18-B16 P93; 95 Q45) - $45
KA24DE SPEC Lightweight Flywheel (Ignore the marker label; mislabeled) - $325
KA24DE CX Racing Aluminum Radiator - $80
SR20DET 5 speed bellhousing - $150 - CB71C
S13 KA24DE Silicone Radiator Hoses - $30
S13 KA24DE Valve Cover - $45 - Unpainted. 4 available
Kaaz 2-way from R200 - $600 SHIPPED
S13 SR20DET BC 264 Cams - $250 - Used, includes intake and exhaust cams
Exhaust
S13 KA24DE Factory downpipe - $50
Thrush Glasspack - $40 - Brand new. Never used, still in the box. Just opened the box to check it out. |Inlet and Outlet Diameter: 2"|Overall Length: 25"|
Turbo Parts
SR20DET Factory Turbo Manifold - $65
Greddy FMIC - $40 - Damaged all over. Does not hold pressure. Can probably be repaired by an experienced welder.
Suspension
S13 Stock Front Knuckle (Passenger Side): Lower hole for the caliper bracket is damaged from the car dragging on the knuckle. A bolt wont fit through - $40
S13/14 Rear Lower Control Arms (no-brand) with Megan Racing balljoint shanks and balljoint hardware - $100
S13 Whiteline Rear Sway Bar (No end-links) - $150
S13 Tokico Blues with Tien lowering springs - $400 - Dont' know the mileage on them but they look like they're in great shape.
S14 Era One Drop Knuckles FRONT ONLY - $100- One of the front knuckles is broken where the tie-rod mounts. VERY used. Requires S14 front hubs.
Exterior
S14 Kouki Grill - $100
S13 PAIR Silvia Headlights, Brick Style with Circuit Sports Lenses, Yellow Reflector and HID Bulbs. (Damaged; shown in pictures) - $440
S13 LEFT Silvia Headlight, Brick Style with Circuit Sports Lenses, Yellow Reflector. (Damaged; shown in pictures) - $100
S13 Hatchback Tail lights (SET, Tinted Center) - $65
S13 Coupe Tail Lights (PAIR, Stock) - $65
S13 Coupe Tail Lights (PAIR, Custom) - $165 - These are 50/50 crystal clear tail lights that have had the turn signal section professionally colored amber. One tail light has a scratch on the side
S14 Zenki Tail Light (CENTER, Stock) - $35
S13 Coupe Tail Light (LEFT, Tinted) - $35ea - Two available, both left side
S13 LEFT Circuit Sports Silvia Corner: The lenses have been colored amber with transparent paint. Original mounting bracket is broken - $30
S14 LEFT OEM corner Light: Damaged - $40
S14 Zenki Turn Signals - $30
S13 Silvia VIS (Supermade Style) Front Bumper - $320 SHIPPED - Never been installed but has minor cracks from being handled
Miscellaneous
S13 Brown Center Console w/ leather armrest - $55
S13 RHD Center Console - $60
GM LQ4/LQ9 317 Heads - $275
S13 Gas Tank Straps - $50
S13 Gas Tank Straps (Surface Rust) - $40
S13 Power Steering High Pressure Hose - $75
S14 Column Controls - $40 each or $70 for both
SSR Wheel Covers - $30
S13 Steering Column - $120 - Doesn't come with the ignition or key. Includes a hub adapter and a solid bushing. All in good shape
R.J.S 5-point Harness - $45 - Two sets available. Both dated 2011
S13 Digital Climate Control - $70 - Control unit ONLY. Does not come with pigtails.
Side mount seat brackets - $50
Bride Seat Rails with side mount brackets - $200 -These were removed to fit lower seat rails. One of the tracks is slightly bent, but it does not seem to affect anything.
RB25DET (Series I) Parts
Oil Pickup Tube - $30
Factory Oil Cooler - $65
CAS Bracket - $55
Harmonic Balancer - $85
Oil Pump - $140
Power Steering Bracket - $50
Throttle Body - $90
Timing Belt Cover Set - $70
Cam Gears + Crank Sprocket - $65
Valve Covers - $90
Valve Guides (Intake+Exhaust) - $130
Valve Springs - $40
Water Pump - $65
Factory Pistons+Rods: All pistons and rods are visually in good shape, would recommend new rings. - $145
Images
'93 Q45 VH45DE ECU w/ Traction Control
'95 Q45 VH45DE ECU
SPEC KA24DE Lightweight Flywheel
S13 CX Racing Aluminum Radiator
SR20DET CB71C Bellhousing
KA24DE Valve Covers
Kaaz 2-way
BC0201 Cams
S13 KA24DE OEM Downpipe
Thrush Glasspack
SR20 Turbo Manifold
S13 Knuckle (Damaged)
S13-14 RLCA
S13 Tokico Blues with Tien Lowering Springs
USDM S14 Kouki Grill
Silvia Headlights (PAIR)
Silvia Headlight (LEFT)
S13 VIS Bumper
S13 Center Console
SSR Wheel Covers
S13 Steering Column
Bride S13 Seat Rails (sliding) with Side mount brackets
gripROYAL is offline   Reply With Quote
Old 11-23-2016, 12:45 PM   #2
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Where are you located?
Old 11-23-2016, 12:54 PM   #3
JC831
JC831's Avatar
JC831 is making a name for him/her selfJC831 is making a name for him/her self
S14 exhaust ? Ill take it if its for s14
JC831 is offline   Reply With Quote
Old 11-23-2016, 01:58 PM   #4
gripROYAL
gripROYAL's Avatar
Pictures cont'd. Prices in OP
Circuit Sports Corner (Amber; LEFT)
S14 OEM Corner Light (Damaged; LEFT)
RB25 Oil Pickup Tube
RB25 Factory Oil Cooler
RB25 CAS Bracket
RB25 Harmonic Balancer
RB25 Igniter Chip
RB25 Oil Pump
RB25 Power Steering Bracket
RB25 Throttle Body
RB25 Timing Belt Cover Set
RB25 Cam Gears+Crank Sprocket
RB25 Valve Covers
RB25 Valve Guides
RB25 Valve Springs - Exhaust
RB25 Valve Springs - Intake
RB25 Water Pump
RB25 Pistons+Rods
Whiteline Rear Swaybar (S13)
S13 Gas Tank Straps
S14 Shifter Trim
S14 Steering Column Controls
S14 Zenki Headlights
SR20DET Downpipe (2.5")
Greddy FMIC
R.J.S. 5-point Harness
KA Radiator Hoses
Side Mount Seat Brackets
S13 Hatchback Tail Lights (SET, Tinted Center)
S13 Coupe Tail Light (LEFT, Tinted, 2 Available)
[/B]
Old 11-23-2016, 02:11 PM   #5
Ken1222
Ken1222 is an unknown quantity at this point
Can you confirm the digital gauge cluster is in working condition?
Ken1222 is offline   Reply With Quote
Old 11-23-2016, 08:33 PM   #6
Pniles856
Pniles856 is an unknown quantity at this point
Is Rb25 down pipe for s13 and do you ship?
Pniles856 is offline   Reply With Quote
Old 11-25-2016, 08:12 AM   #7
gripROYAL
gripROYAL's Avatar
The RB25 downpipe was used on an S14 but both S13/S14 use the same downpipes/mounts etc. so it should be fully compatible with an S13.
Old 11-25-2016, 11:25 AM   #8
niSm095
niSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really nice
Still have the rear swaybar?
niSm095 is offline   Reply With Quote
Old 11-25-2016, 11:48 AM   #9
gripROYAL
gripROYAL's Avatar
Yes! Please dm to order with all your shipping details, contact email and phone, and we will send a paypal invoice.
Old 11-29-2016, 12:26 PM   #10
gripROYAL
gripROYAL's Avatar
Bump. Added LS1 Intake, S13 Passenger side knuckle, S14 lowering springs, Silvia brick-style (bricks) headlights, RLCA
Old 12-02-2016, 12:49 PM   #11
gripROYAL
gripROYAL's Avatar
Bump. Added RB25 Parts, KA24DE Spec Flywheel, Buddy club seat rail, Silvia corners
Old 12-06-2016, 01:54 PM   #12
gripROYAL
gripROYAL's Avatar
Bump. Added S14: Headlight housings, turn signals, steering column controls, shifter bezel (automatic). S13: Gas tank straps, power steering hose, whiteline rear swaybar. SSR Wheel covers, SR20DET Downpipe.
Also: Damaged Greddy Intercooler
Old 12-06-2016, 04:39 PM   #13
85efi
85efi is an unknown quantity at this point
Can you pm me a price for the downpipe (flex) shipped to CA 91306...
TY
85efi is offline   Reply With Quote
Old 12-07-2016, 03:38 PM   #14
gripROYAL
gripROYAL's Avatar
Bump. Added S13 ECU, S14 Era One drop Knuckles, KA24DE Aluminum radiator, Megan Racing Coilover springs, 5-point racing harness, S13 digital climate control, KA24DE silicone radiator hoses, Side mount seat brackets
Old 12-12-2016, 03:06 PM   #15
itsjustdaphne
itsjustdaphne's Avatar
itsjustdaphne is a well-known jackass
For quick sale of the ECU's, send an email to [email protected]
@ddaapphh | @spectuned
itsjustdaphne is offline   Reply With Quote
Old 12-14-2016, 09:44 AM   #16
gripROYAL
gripROYAL's Avatar
Bump. Added USDM S14 Kouki Grill and Kaaz 2-way
Old 12-20-2016, 04:27 PM   #17
ikaharding
ikaharding is an unknown quantity at this point
How much to ship KAAZ two way to NZ ?
ikaharding is offline   Reply With Quote
Old 12-21-2016, 08:23 AM   #18
gripROYAL
gripROYAL's Avatar
Please pm us your full shipping address; I'd imagine it's going to be pretty expensive.
Old 01-13-2017, 09:46 AM   #19
gripROYAL
gripROYAL's Avatar
Bump, Updated list
Old 01-13-2017, 11:40 AM   #20
Lindsay Lohan
Lindsay Lohan's Avatar
Lindsay Lohan is an unknown quantity at this point
you know how to do the do. setting the standard in automotive for sale sections for the zilvian mind. happy saling.
Lindsay Lohan is offline   Reply With Quote
Old 01-23-2017, 10:33 PM   #21
IvanJay
IvanJay is an unknown quantity at this point
Would you be able to provide measurements of the circuit sports silvia signals? Wanting to see if they fit my Origin aero. Thank you.
IvanJay is offline   Reply With Quote
Old 01-24-2017, 09:15 AM   #22
gripROYAL
gripROYAL's Avatar
Sorry IvanJay, we hadn't updated the thread in a few days and those are no longer available. I think you can still find these new online though and believe they're the same size as oe style for any silvia bumper.
Old 01-24-2017, 07:44 PM   #23
zombiewolf513
Diggin the lightbox. Interested in the ssr wheel covers here
Old 01-26-2017, 08:08 AM   #24
Nicg90
Nicg90's Avatar
Nicg90 is an unknown quantity at this point
2.5 sr20det downpipe still available?
Personal IG: nic_giannini
Club Sandwich IG: clubsandwichstreetteam
Nicg90 is offline   Reply With Quote
Old 01-26-2017, 09:01 AM   #25
gripROYAL
gripROYAL's Avatar
Yes, this item is still available. PM to purchase please!
Old 01-31-2017, 07:43 AM   #26
gripROYAL
gripROYAL's Avatar
Thread has been updated - we have quite a few items still left. We can send a paypal invoice for these items to allow you to pay via paypal, credit, or debit card (regardless of having a paypal account or not). Please PM us if you have serious offers or want to combine items for a discounted price. We need to clear up some shelf space so please hit us up! Some good items left such as the kaaz 2way and bc cams etc. -Scott
Old 02-07-2017, 07:31 PM   #27
itsjustdaphne
for ecu's ask rs-enthalpy, message them on fb
Old 05-31-2017, 11:25 AM   #28
gripROYAL
gripROYAL's Avatar
BUMP, these items are still available and we are able to ship them out pretty quick. LMK if you're interested in anything, thanks!~
Old 05-31-2017, 12:50 PM   #29
nisileighty
nisileighty's Avatar
nisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of light
Was there a buddy club on this list at one point?
nisileighty is offline   Reply With Quote
buddy club, grip royal, ls1, ls2, sr20
