Old 09-07-2008, 08:39 PM   #1
TwiztedZero
TwiztedZero's Avatar
TwiztedZero is an unknown quantity at this point
1992 S13 Kouki front end/rear conversion
I'm looking for any information anyone has about wiring up and fitting the Kouki front bumper and rear taillights. I've had these sitting around for awhile and I'm ready to put them on and would like to ask some experienced people for any help!
Thanks!
-Steve
TwiztedZero is offline   Reply With Quote
Old 09-08-2008, 03:37 AM   #2
eek
eek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud ofeek has much to be proud of
Try using the SEARCH feature.
eek is offline   Reply With Quote
Old 09-08-2008, 09:49 AM   #3
TwiztedZero
I've tried searching out as many combinations with S13 Kouki swap as I can, but it's just cars for sale/parts for sale/etc.
I understand that was my first post and all, so flamebait, whatever, I'm just looking for some experienced advice.
Old 09-08-2008, 10:54 AM   #4
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
Search for "S13.4" for the front. The rear you will be on your own.
g6civcx is offline   Reply With Quote
Old 09-08-2008, 11:10 AM   #5
Sileighty_85
Sileighty_85's Avatar
the rear is no biggie you MUST have the kouki Wire harnesses for the lights
Everything bolts up you just have cut the the Kouki Plugs and wire them to the S13's OEM plug.
Just do it a wire at a time, and use a test light if you have to.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 09-08-2008, 08:53 PM   #6
TwiztedZero
Yep, I know that the lights/garnish plates will all fit up right, and I definitely found out the connectors are different, but as far as the harness goes, I just have the chuki harness on the car and just the plugs for the kouki lights, so is that what you mean by the wire harenesses for the kouki lights?
Also, by Kouki front end I mean, the S13 kouki front end, not switching to a 14. I just wanna hear what others have done as far as wiring the corner and marker lights. I'm pretty sure I can make the right swaps on the brackets from the chuki bumper...
