Old 08-31-2013, 02:56 PM   #1
jk26
Trader Rating: (31)
jk26 is an unknown quantity at this point
Feedback Score: 31 reviews
Ultimate rb26/30 part out Tomei, Nitto, 6Boost, Greddy, Hks..
Im parting out my car and here are most of the engine components I was planning on using, im slightly negotiable on pricing so offer up. I also have more parts coming as well as a widebody zenki s14 shell with version select, origin, dmax, and other quality parts. Thanks
-Rb30 series 1 block with micropolished crank this block is ready to go just needs a hone- $1500 Sorry no pics right now the motor is at Total Engine Concepts and I can get pictures for seriously interested parties
-Brand New nitto I beam rb30 rods these are some of the best rods you can get for the rb30. looking for $1050
-Tomei Oil pump roughly 3k miles gear looks new asking 1200
-n1 water pump same mileage and condition as the oil pump asking 125
-r32/33 CAS with bracket -$60
[/URL]
RIPS brand new 7qt oil pan with extended pickup asking $600
RIPS larger crank collar $50 and RIPS head return system- $175
Brand new rb25 ARP head and main studs- $125 for the heads studs, $150 for the mains
RB26 R34 Head this head has a 5 angle valve job with oem valves, new Tomei exhaust valve guides, clearanced for high lift cams, and ported exhaust hump knife edged port divider. looking for 1100.
6boost forward facing manifold T4 flange with a 60mm v band wastegate flange looking for 1100
HKS GT1 60mm wastegate with ss vacuum lines, dump tube, and extra blue spring - $300
Brand new greddy exhaust and intake cam gears $300
Brand new greddy fuel rail with fittings and hardware-$240
Brand new Yellow Jacket coil packs for r32/33 $400
Brand new Borg Warner s366 extended tip light surface rust on exhaust housing and front bolt- $550
Custom 4" down pipe and 4" exhaust came off a r33 rb26 $ 600 pics of piping and can later
Flex a lite fans $250 Koyo radiator- $200
r34 polished valve covers and center piece with greddy clear timing cover $600
Brand new Ross metal jacket damper for rb25/30- $575
Tomei 87mm 1.2 thick headgasket for rb26 brand new - $240
Greddy 3 row 4" intercooler off a supra fresh polish- $850
r34 nismo white face 11k cluster $600
Brand new rb idler and tensioner pulley -$55 for both oem rb oil filter $10
rb26 intake plenum with itbs needs gaskets and hardware $250
Tilton OTII Clutch mated to an oem rb26 machined flywheel needs discs -$450
Setrab oil cooler set up with hks thermostatic oil relocator, ss lines, and aeroquip fittings, needs screw on piece for oil tree or block off if using with an sr20 $400
Lastly is a low mileage good condition rb25 transmission just needs a slave no pics yet $800
jk26 is offline   Reply With Quote
Old 08-31-2013, 08:55 PM   #2
smoked240
smoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymore
Send a message via MSN to smoked240
Damn a lot of nice stuff here! If I had the money I would buy it all up. I'm interested in the intake plenum and itbs. Would you do $250 shipped?
smoked240 is offline   Reply With Quote
Old 09-01-2013, 08:29 AM   #3
Kinda-Important
Kinda-Important is an unknown quantity at this point
will fuel rails work on rb25?
Kinda-Important is offline   Reply With Quote
Old 09-01-2013, 09:48 AM   #4
funktown240
funktown240 is an unknown quantity at this point
Just a bare block with crank? No rotating assembly? Details please.
funktown240 is offline   Reply With Quote
Old 09-01-2013, 10:15 AM   #5
BossHogg
BossHogg's Avatar
BossHogg is an unknown quantity at this point
Fuel rail should work. Might have to use spacers etc.
Idler/tensioner, ross tuffbond, arp headstuds sold :-)
Bump!
BossHogg is offline   Reply With Quote
Old 09-01-2013, 02:41 PM   #6
Kinda-Important
Bump!
thanks!
Old 09-02-2013, 12:32 PM   #7
jk26
Trader Rating: (31)
Be a baller and buy some of these parts, I can also get someone a discounted rate on the custom CP's needed to run those rods.
Also ill be adding
-AEM v1 ems with MAP sensor
-jgy motor and tranny mounts
-jgy aluminum 1 piece driveshaft
-Aeromotive frp
-defi gauges with controller
Old 09-03-2013, 05:45 PM   #8
jk26
Trader Rating: (31)
Idler, tensioner, Ross metal jacket, and head studs shipped. Everything else is still for sale.
Old 09-03-2013, 08:32 PM   #9
Ramius83
Ramius83 is an unknown quantity at this point
Can you post more pics of the turbo please. What size A/Rs on the housings, bolt patterns/mounting, etc.....
Ramius83 is offline   Reply With Quote
Old 09-03-2013, 08:51 PM   #10
S14rb25k
S14rb25k is an unknown quantity at this point
Send pm thanks
S14rb25k is offline   Reply With Quote
Old 09-03-2013, 09:23 PM   #11
omgRWDgoodness!
omgRWDgoodness!'s Avatar
Trader Rating: (48)
omgRWDgoodness! is an unknown quantity at this point
Feedback Score: 48 reviews
Wow, someone in Boca that actually has good parts? Bump for you.
omgRWDgoodness! is offline   Reply With Quote
Old 09-04-2013, 07:09 AM   #12
BlewByYou
BlewByYou's Avatar
BlewByYou is an unknown quantity at this point
Sounds like you had everything to get it going.. Would have been a killer machine!!
BlewByYou is offline   Reply With Quote
Old 09-04-2013, 06:12 PM   #13
jk26
Trader Rating: (31)
Thanks for the compliments guys, the intake manifold has sold and as promised added parts
JGY aluminum driveshaft-300 OBO
Aem ems version 1 with 3.5 map sensor - 950
Rb25 series 1 transmission roughly 40k- 800 OBO
Old 09-07-2013, 11:41 AM   #14
jk26
Trader Rating: (31)
Bump accepting reasonable offers on some stuff
Old 09-07-2013, 03:47 PM   #15
dftsilvia
dftsilvia's Avatar
dftsilvia is on the path to ruindftsilvia is on the path to ruin
200 shipped for the rb26 intake setup to 14210?
dftsilvia is offline   Reply With Quote
Old 09-07-2013, 11:51 PM   #16
bvr463
bvr463 is an unknown quantity at this point
bump this good thread up
thank you!
bvr463 is offline   Reply With Quote
Old 09-09-2013, 05:28 AM   #17
BossHogg
BossHogg's Avatar
received my parts very quick. Don't be afraid to buy!! It wasn't exactly a "cheap" purchase either.
Old 09-09-2013, 10:20 PM   #18
jk26
Trader Rating: (31)
Tomei pump, greddy gears, arp main studs, and head drain all sold
Old 09-10-2013, 06:34 AM   #19
ZT-R
ZT-R is an unknown quantity at this point
would you sell the crankshaft and rips pan? send more pic of pan and oil pickup...
pm me if so.
1972 Datsun 240z that thinks its a Skyline.
ZT-R is offline   Reply With Quote
Old 09-10-2013, 11:05 AM   #20
ZT-R
oh for some reason my pm's go to a different user (2004ztr) which is not me so i guess just post it here or something.
Old 09-10-2013, 01:56 PM   #21
Ramius83
Still going to keep at the old RB30 ZT-R????? Find anything new with it????
Old 09-10-2013, 02:07 PM   #22
ZT-R
Yea im gonna give it one more go then an ultimate part out if it blows up again.
Old 09-12-2013, 04:58 PM   #23
jk26
Trader Rating: (31)
Pictures of the crank added, block pictures coming later.
Old 09-25-2013, 11:29 PM   #24
JBotch79
JBotch79 is an unknown quantity at this point
What defi gauges do you have?
I Cut Vinyl Stickers
www.facebook.com/precisionvinylworks
JBotch79 is offline   Reply With Quote
Old 10-01-2013, 10:19 AM   #25
richmond82
richmond82's Avatar
richmond82 is an unknown quantity at this point
Bump to the top ! lots of baller parts ! Great seller
Drake: 95 Swapped S15SR Z32 Swapped TT 1991Vert
richmond82 is offline   Reply With Quote
