Old 10-08-2010, 11:10 AM   #1
eklips3
eklips3's Avatar
eklips3 is an unknown quantity at this point
voltage drop from switched 12v
weird issue here, cant really think of any solution.
i've got my fan controller wired up to the switched 12v source coming off of the window washer pump.
anyways when im driving , and this only really happpens during the day when its hot outside, the fans just turn off. but when i turn the car off when this happens and put the key to the 'on' position the fans turn on. i start the car again and the fans turn off.
i looked at the voltage going through the 12v wire going to the fan controller with a multimeter and when its acting up i dont get more then 5 volts...
but when everything is working fine i get a voltage reading of 12.2 volts when the car is off and 14v when the car is on.
any thoughts guys ??
thanks.
1992 240sx (RB20. [email protected])
eklips3 is offline   Reply With Quote
Old 10-08-2010, 12:24 PM   #2
modulation
modulation is an unknown quantity at this point
thanks.
Is it possible anything is slightly shorting to ground, or you are using a relay or something that doesn't like the heat?
modulation is offline   Reply With Quote
Old 10-08-2010, 01:00 PM   #3
s15specR
s15specR's Avatar
Trader Rating: (18)
s15specR is making a name for him/her selfs15specR is making a name for him/her self
Feedback Score: 18 reviews
What fan controller are you using, are you using relays to turn your fans on through a fan controller ?
s15specR is offline   Reply With Quote
Old 10-08-2010, 05:56 PM   #4
eklips3
eklips3's Avatar
yeah the fan controller has an integrated relay.
its a really cheap fan controller that i got here. i dont even know what the name of it is.
there are no shorts.
Old 10-08-2010, 06:14 PM   #5
klits562
klits562 is an unknown quantity at this point
the relay might be cheap and over heating like someone above stated.
klits562 is offline   Reply With Quote
Old 10-08-2010, 06:14 PM   #6
modulation
I'd suspect the fan controller being screwed up by the heat.
Old 10-08-2010, 10:11 PM   #7
eklips3
eklips3's Avatar
yeah i thought it would be the relay as well
thanks alot for the input guys.
