Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Drivetrain
Old 10-05-2012, 09:33 AM   #1
Mazworx_Sales
Mazworx_Sales is an unknown quantity at this point
Mazworx | Exedy Clutch Clearance
We currently have 2 clutch kits instock that we would like to clear out.
Exedy Stage 1 SR20DET - $269.00 SHIPPED!
EXEDY organic racing clutches only use premium friction materials that are resistant to slippage and burst. Increased clamp loads give the necessary capacity to handle modified engines. This is the preferred clutch for street and light horsepower track use. Driveability is similar to the stock clutch. Pedal efforts will be slightly higher because of the higher clamp loads. All of our clutch discs have spring center dampers to reduce drivetrain shock.
Exedy Stage 2 Thick SR20DET - $319.00 SHIPPED!
EXEDY cerametallic clutches are designed to handle the abuse of high powered modified engines. Our cerametallic friction material can handle much more slippage than stock type disc assemblies without slipping and fading. All cerametallic discs feature spring center dampers to reduce impact and shock loads.
Normal Thickness (Thick)
Normal thickness discs have greater heat capacity and therefore better durability in demanding applications such as all wheel drive.
www.mazworx.com
[email protected]
Nissan S-Chassis and SR20 Specialists!
*Your #1 source for all engine/machine work.*
M-F 9-6pm EST
Tel: 407-281-1223
Pro Modified S15
Best ET 7.36
Best MPH 184.00
Sport RWD S14
9.07 @ 155
Mazworx_Sales is offline   Reply With Quote
Old 10-05-2012, 09:46 AM   #2
801nismo104
801nismo104 is an unknown quantity at this point
how much power can the stage 2 hold?
801nismo104 is offline   Reply With Quote
Old 10-05-2012, 11:05 AM   #3
Mazworx_Sales
Around 450
www.mazworx.com
[email protected]
M-F 9-6pm EST
Tel: 407-281-1223
Pro Modified S15
Best ET 7.36
Best MPH 184.00
Sport RWD S14
9.07 @ 155
Old 10-05-2012, 11:52 AM   #4
towlie
Pm sent
10char
Old 01-28-2013, 10:50 AM   #5
S14.5drifter
S14.5drifter is an unknown quantity at this point
Send a message via Yahoo to S14.5drifter
s15 s15 6 speed transnission problem
Originally Posted by Mazworx_Sales View Post
Around 450
Hi guy,,, i need to know if you guy can custom make the front cover where the release bearing goes of my transmission,,, please let me know.
Thank you
S14.5drifter is offline   Reply With Quote
