Old 03-08-2014, 12:52 PM   #1
Rpalm240sx
Rpalm240sx is an unknown quantity at this point
S13 led turn signal problems help please!!
Ok so I bought led side marker lights and front led turn signals for my s13 http://bit.ly/1brlry4 http://bit.ly/1lJajoF and then I bought a led compatible hazard flasher the e34 or something like that. Well the hazards works fine an when I use the turn signal it turns all the signal lights on (like the hazards) an can't use turn signal when parking or running lights are on at all any input thanks!
92 sr20det red top hatch
Rpalm240sx is offline   Reply With Quote
Old 03-09-2014, 07:14 PM   #2
Zeratul
Zeratul is an unknown quantity at this point
If you have USDM front signals, then you need 1157 bulbs. Just look at the base of your original bulbs or signal sockets to see if they have 2 contact points per side.
And, for led bulbs, you should use the same color as your lenses. Amber bulbs for amber lenses. Otherwise the light will be dimmer.
Zeratul is offline   Reply With Quote
hatchback, led, s13, sr20det, turn signal help
